Brillos Builds
I’ve torn my pants a couple times on pieces of the rocker sticking out, and I pretty sure I could kick the frame into two pieces
Yup wait till we get the frame photos so everyone can see how bad this one is. I still cant believe the PO drove it home to pull the transmission...:/
Sent from my SM-J337V using Tapatalk
Tetanus 1 got a replacement seat belt today. The old one wouldn't wind itself up anymore without assistance
[MENTION=318903]RandyBobandy[/MENTION] and I hit a local pick and pull. I got doors for the wife's sienna van and a set of tocuma lock out hub assembly for our 3td gens . :D
Out of luck for the Tundra calipers that fit the 16 in wheels. However, we did ok..;)
Why you replace the insert. Careful with the center screw that goes all the through or you loose the little nut..;)
As you can see my paint and FF looked exactly how they did when changed the fenders last year. I was curious how it were would hold up in there and its perfect..:)
$65.00.
Wow, great price.
I found one that was same color and “supposedly” original paint......NOT!
Drove 120 miles only to find a rusty tailgate that had been sprayed at least once, asking price of $250....PASS!
The proper way to repair that antenna is to get one from the parts store that doesn’t really fit, and then glue it in place without hooking it up to the radio, because your significant other says it looks stupid with it missing.
I have NOT done that, but I think that’s how the service manual says to do it
Wow, great price.
I am sure this was repainted However. Eventually I have to paint this one to red. For the condition and price I couldn't go wrong.
Got it all back together and will verify no leaks for a few days before putting the engine skid back on. :)
should have put a big all aluminum rad on there, the extra cooling capacity will be necessary when we bolt a huge ebay turbo on there making like 50psi of boost
Or that external tundra coolers we were looking into at that pick and pull. :)
Working on my 5 speed frame seal and inner plate project. You can see the frame is decent in this section. I did clean and corroseal the frame. Now I can weld new plates in and reseal the frame back upon this area..:)
