Bumper Paint Repair - DIY Progress
So as I posted in another thread, I backed the left rear corner into a wall and scraped the rear bumper cover. The quote I got was $930 with insurance or $870 if I pay out of pocket. I've done some painting in the past as a hobby working on my '56 Chevy. It has been about 8-10 years since I've touched my paint gun and I threw out all of my extra paint and solvents about 5 years ago. I decided to stop by the auto body supply store after getting the estimate and materials came to about $150, plus another $50 for misc, mask, light, etc...
This is my first attempt at a spot repair. Here is the damage:
Sanded it down to get the scratches and rough edges out:
Some Primer to fill deep scratches, sanded, re-primer, and repeat:
Ended up doing a larger area to cover some other scratches, had to stop myself as the area kept growing as I found more chips and scratches:
Redid the tape to go beyond the base coat and applied 3 coats of clear. I should have masked a larger area here and left the edges to have fanned out a little and not worried about getting a good finish. Instead I painted right up to the tape even though it was rolled and got a pertty goo lip I need to deal with now:
here you can see the edge I need to wet sand down and bufff, we'll see how that goes. Hopefully I don't end up redoing the whole thing.
the match looks pretty decent out in the light:
If I had to do it again I would paint all the way to the top, front and bottom edge so that I only have a vertical masking line on the rear of the car to deal with. I was too lazy to unbolt the bumper and in the beginning I wasn't planning on doing an area much larger than what I had masked in the first pic. I'll post some updates on my progress or regression.
From what i can see, it looks like it turned out pretty good. Luckily you didn't have blizzard pearl.
Yes! Almost did too, fortunately the sales guy got all pissed off when I told him what I wanted to pay since I already had an offer from another dealership for a black with black interior. They were hard to find at the time so while I was waiting to see how long it would take to be delivered I checked out the white one at another dealership. I was okay with the white, but due to the guys attitude I ended up leaving, he was mad at me for having gotten a better price. Funny thing is before I left he was able to give the price which he swore was impossible...
I'm guessing even though its pearl that it probably hides scratches better than the black and the water spots!
UPDATE and DONE!
Well, hope everyone had a a good Christmas or time off if you don't celebrate Christmas. I got Wendesday off before work which I decided was a good time to knock this out. I decided to post some pictures of the bumper off incase anyone wants to see what's holding everything on in the event they want to remove some of the trim, parking sensors, or see what the bumper support looks like.
The bumper released from the clips really easily, just need to be careful with the clip under the tail light. Just wiggle the sides and it pops right out. I did break a clip under the right side tail light, I had released it then when wiggling the right side it pooped back in. then with slight tug I saw the little black piece of plastic go flying by my face.
In short, here is what I did.
  1. removed bumper
  2. sanded out old clear (my old mistake above) and other scratches/chips
  3. scuffed clear coat
  4. base coat the entire bumper, then clear coated the entire thing
Here is what it looks like with the bumper cover off:
These are the clips that hold the trim on(same on the other side) note that the ones without the blue clips have a tab built in that needs to be depressed to remove it:
Parking Sensor has 2 tabs, one on each side that need to be lifted to release it. The trim piece on the bumper can just be squeezed in and pushed through the hole. I didn't notice removing them but the sensor will only go into the trim one way so look at the fitment before putting the trim piece back into the bumper. Might not be as obvious if you're messing with them with the bumper still on:
This is the only thing that really gave me any trouble, I could not get it to release nicely.
I was worried about making the transition to the unpainted area look as it did out of the factory. I masked it with some 3M thin masking tape, not the fine line stuff for graphics this stuff was cheaper. I followed with thicker masking tape and plastic:
Turned out well:
After clear, didn't take any with just base, it just looked flat black:
All done!
Very nice work! Now... time to wash! ;) I commend you on owning black.... I tried, I really did. In the end I traded in the black for Mag grey.
This is awesome... I may need to venture in to this one day. Do I just need a spray gun, compressor and some paint?
More or less, I'd recommend a good respirator too. Go into your local autobody store and they should be able to give you all the info you need or at least that has been my experience now and in the past. I'd buy my equipment online though and find something to practice on. Painting really is the easy part once you figure it out, the quality of the final finish is really all in the prep work though.
I think I'm pretty much done with painting for now. It makes such mess and the smell is really strong. I guess I was a pretty inconsiderate neighbor/roommate in college :noidea:. Well, I helped my roommates paint their stuff so not so much to them. My furnace is in the garage at my current home and it just distrubuted the smell everywhere, I had to open all of the windows and turn on the whole house fan for a couple hours while we left to clear it out. I need to fix some major leaks on the intake side though and that will help, but its still just a mess with the over spray. I've made some homemade booths but it is still messy. Small parts aren't bad though.
