Bump's '90 4Runner
I guess I should update this. Ive got a few hundred miles on the 4runner now, but Ive had a few issues. First issue when I got it moving was the transmission didn't have 2nd or 4th. Ended up taking the trans out and having someone go thru it. Then after riding around the national forest all day, I had my fuel line blow apart. So I replaced the spliced together fuel line with some braided SS line with AN fittings. Then shortly after that, I had the driver side front brake caliper come off and blow the rotor apart. Im in the process of fixing that as we speak. Ive also wore out the front spring bushing (shackle end) quickly. So I ordered some Dave'z shackles to hopefully solve the problem. The shackles should be waiting on me when I get home.
Rear shock install
Steering shaft extension with 1"x0.12 wall DOM
Front shock hoops
Tcase shifter cover
Just a random pic of the 4runner put together
Wore out spring bushings
Busted rotor
damn this thing is nice !!! :thumb3::thumb3::thumb3:
Thanks. Its been a lot of work lol
I guess I should give a little update. I got the brake situation fixed. I replaced the rotor and knuckle. I also installed Dave'z shackles on the front springs. They were a little bit of a pain to install, but I think I can do it a little easier next time. After driving it for a couple days, the front spring bushings gave up. Did I mention that TG's spring bushings suck? lol. I have some energy suspension bushings coming to replace those. Im also going to run a sleeve in them like the Dave'z shackle setup so all my bolts will be the same size. Here's some pics...
Dave'z shackle
And the wore out front spring bushings
Still haven't fixed those front bushings yet, but I did take it out on a buddies lease Saturday.
Hoping to get it back in the shop to replace those bushings and build a front driveshaft this week.
Thanks. The only bad part about those shock compressors is they burn easy when tacking shock mounts. So use cheap straps lol.
Nice looking runner. I am planning the same swap this winter. What all did you need from the donor truck besides the engine computer and harness? What emission control crap did you have to swap over? I dont have to take my runner through emissions anymore (it's to old thank god) so i don't exactly need them but just wondering if any of the crap was needed to get the engine to fire and run smooth. Nice build
Thanks. Im not sure what all I posted on this thread, but I deleted all the emissions. We don't do emissions testing in Louisiana. Really, just the engine, harness, and computer is about it. What transmission are you planning on running?
So how did you eliminate the emission controls? Do you just use like an EGR block off plate and plug the vacuum hoses? Thats the only thing i am trying to figure out how to get around since now i have a wiring guy to help me wire the engine. What all did you leave in ur 4runner? Sorry ill be picking your brain for help. I am going to subscribe to your build though since you are doing about the same thing I am and its one hell of a runner. Im not totally decided yet on my trans. I want to keep it manual. Not sure if i am going to go with a chevy trans or use the toyota one. I think im going to end up using a chevy trans and transfer though. I kinda only want to have to build it once. If all i have to do is eventually go to a small block thats easy if i already have the chevy trans. I was thinking about useing an old school 4speed with the granny gear since they are solid and my runner is going to be on a trailer once i do my SAS more than likely. Im looking into doing 1ton axles.
Yeah I used a EGR block off plate and a plug for the EGR tube that goes into the intake. I had the computer reprogrammed to delete the emissions controls. The only vacuum hose was the on the solenoid going to the evap canister. I just left that solenoid on there unplugged for now. The only unresolved item I have left from the emission delete is what to do with the gas tank vent that went to the evap canister. Ive had a few ideas but haven't done anything yet. Of course, all this applies to the 96 and up engines. The TBI's are a little different but not much.
Awesome. Im going to use one that is newer than 96. Probably 2000 or so since from what i researched they have the highest hp and torque rating. Since i am going to have to get the computer reprogramed than i may as well beef up the engine a little bit then. What all did you need to leave in your runner and what did you take out?
Im not sure what you mean by what did I take out and what did I leave. I pulled almost everything out of the engine bay. I think there are some pics in this thread.
As far as HP, the 96 and up in the vans and full size trucks had 200 HP. I think it took a little while for the S10 motors to catch up. Im pretty sure that's the most they put out until like 2013 or so.
Like fuse box and any other little things that needed to stay with the truck. You are right on the hp.
The fuse box is about all I kept. If i remember right, its not hooked up to the motor another to the alternator. I cant really remember anything else that I left.
Sweet. So i think i saw that you are running chevy 63's? Did you get the hangers from the truck that the springs came from or were they something that you bought? Are you running the chevy springs in the front also? My bro in law has a blazer he is about to send to the scrap yard and im going to get his springs and im trying to see if i need to use the spring hangers from his chevy or not. Thanks again for all the info. This is going to help out alot when it comes time to start building.
seltzernator
