Bushwacker made fenders for the 5th gen!!
For sure, i'll update you, but I'd say with 90 percent certainty I'll ditch the BW flares and just line-x/rhino line the stock flares. But if your goal is to use the snorkel, which I know isn't out yet, then likely you'll have to opt for the stock flares over these.
At least this won't comes as a surprise. Will let you know for sure though.
Yeah snorkel for sure when it comes out. I'm going to be putting line-x on the front bumper in the spring so I will just have him do the stock flares while at it
The only weird spot is the rear bumper, since it doesn't actually have a flare, but rather it's a part of the plastic molding. So that needs to be masked off and lined. Know what I mean? Same with the front bumper.
Yep I know exactly what you're talking about. Good thing is that we do a lot of business with a local line-x shop so even if it's a weird request he will help me out
Bingo. On mine it'll be the left/right rear bits going down about 4-5" on that plastic bumper. If it's well masked it should be fine.
Since my new front bumper goes on right at the panel line of the front bumper I only have to line-x the front flares without worrying. Again would have loved the BW flares but even if the height wasn't an issue the width sure is.
Ok Here is the finished result. I tried to provide multiple angles for your viewing pleasure.
This shot! :party:
I honestly didn't like the flares until I saw that pic. Everything just works.
Thanks, one more nail in the coffin for these for me. At least now I know.
Yeah I hear ya, you almost have to run spacers though unless you get wider tires. It just doesn't look right. Good thing is there is no rubbing in the front going forward but slight rub in reverse at full lock. Bearable
Totally unacceptable given I'm usually aired down when in the desert. So yeah no go, not down with spacers. Thanks.
