Can I Turn My Lights Off On My 2002??
predatorsniper1
I HAVE AN 02 4RUNNER, IS THERE A WAY TO SHUT OFF MY LIGHTS, THEY ARE ALWAYS ON. THE DRIVING LIGHTS ARE THE SAME AS MY REGULAR NIGHT LIGHTS.
THANKS, MIKE:confused: :confused: :confused:
Rock Slide said:
They're called DRLs - daytime running lights. Typically, drls shine at less power. Once you turn your lights on, you headlights reach full power.
But to answer your question, yes, they can be disabled. I've done it and it works great. Just be sure to cut the correct wire:
Write up: http://www.yotatech.com/f127/2002-4runner-drl-disable-off-capability-87596/
Awesome, your the man. It looks like I can use a switch to enable and disable the DRL system, is that what you see?
On my 2001 all I had to do is cut 1 wire. Search and you will find enough info info to make your eyes bleed.
That is correct. You can install an on/off switch to control your drls. That was simply more work than I wanted to do, so I didn't bother with a switch...I just snipped the wire like the write up said too.
However, if you do want to install a switch like he has done, this is what he used. As stated in his write up:
The DRL disable switch:
Using an OEM Window Lock-out Switch
(Pt# 84821-35020)
Where do I find these additional switches....:confused:
Now I'm :confused:. What additional switches are you talking about?
Like the Fog light switchs or the window lock switch so I can do this DRL delete?
Well, as I stated you can you this:
(Pt# 84821-35020)
OEM meaning, something you would purchase from a toy dealer or online wholeseller of used toy parts. Other than the dealer, try some places online or junk yards that might sell used toyota parts...that is of course if you want to stay with oem switches.
If not, the aftermarket world is full of fog light switches that could be used. I've even purchase a few fog light switches from Lowe's Home Improvement ($12 ea.) for other mods.
UpNorthMN said:
With all the crappy drivers out there, why would you want to disable this?
This has been covered at nauseum. Do a search for "drls" (you could even search using my username while you're at it too) and you'll find plenty of justified reasons why myself and others have disabled them.
Long story short, I use to be a private investigator. I found it quite impossible to stay hidden while following suspects at night without being able to turn my headlights off. It was a no brainer for me to disable them. :bigok:
You don't need any other switches, wires, etc. All you need is a pair of wire cutters and a little bit of electrical tape. Just cut the specified wire (MAKE SURE IT'S THE RIGHT ONE!) and tape them off. If you want lights during the day again, just turn that knob to the left of your steering wheel!
I also find DRL's useless. But I do leave my lights on during the day. Luckily the Tacoma (and the 01+ 4Runner. Maybe 99-00's, too) has an "idiot proof" feature that turns off the lights automatically when you open the door, so that the "idiot" doesn't drain the battery in the middle of nowhere. :D
Thank you for posting this haha I've always wanted them off, but always forgot to actually research it. Just did it, but uh don't forget to depress the lever on top of the plug to pull it out haha I couldn't figure that out so I pulled the whole assembly out like an idiot haha even still it only took me 5 minutes.
Anyone have a photo of the module and wire? That yotatech link doesn't have pics up. I wanted to disable my 02 drl
The link showing the pictures does not workkk
Anyone have a picture of where this yellow/black wire is located so I can cut it? Thanks,
Extend the life of your bulbs and off-road pics look awful with headlights on. You still have your lights when you need them. I don't need headlights on eight hours of driving off-road in daylight. Back before DRL the rule was, dusk to dawn and wipers on lights on. Smart drivers will still put their lights on when needed.
EDIT: [MENTION=85414]I_bRAD[/MENTION] this is only for the 4runner. My other cars I have no desire to kill the DRL's. They don't have PIAA bulbs and never go offroad. Even in offroad conditions such as Brown's Camp, we still put our lights on most of the times and turn them off for the photo's.
You know, that's a really good point. I'm pro lights-on all the time for safety, but in reality that means I never use my DRLs anyhow, I have the full system on. But that's driving in general, not just the 4runner so I never really considered the need offroad. I still think all lights on is the safest on the road no matter the lighting conditions, but I do see some valid reasons for switching or killing your DRLs.
drl%20mod_zpsfrojwlb7.jpg~original
second hand knowledge
