Can you fit 285/75/16s on stock suspension?
miles
I want to buy new tire right now before I do my lift but Im not sure if 285/75/16s will fit on stock sh#t! Does anyone know?
Yes, you'll need a 2.5" lift to clear 285's. Also, depending on the tire, you'll need wheels with different backspacing too. Some A/T style 285's will fit on the stock rims, almost no M/T's will fit. The issue is with the upper a arms. You can buy wheels with 4.5" of backspacing.
They look the same
I looked at a 265/75/16 and a 285/75/16 side by side and there wasnt too much difference between the two! A little difference but not much so I dont see why they wouldnt fit?
Looks are deceiving and many have tried it (very many) but they rub on the inside of the front tires,I think it's the control arm. Plus you have no room for any play with 285 with stock suspension so you'll be hittign your wheel wells quite frequently.
I have 275/55/r20 and they are super cloase to rubbing the A arms, they don't rub the fenders wells unless I cut it all the way one direction and flex, I couldn't imagine a 285 fitting....
Shonuup said:
285/40R22s on Custom lowered 4runner :) ...no problems and is a very clean fitment. No big gaps.
And comparing two totally different things. This is for off road apps and the ? was 285s on stock wheels and suspension.
:confused:
the reply is that 285s will fit with stock rims especially if they fit with 22 inch rims on a vehicle that has less clearance than stock.
Shonuup said:
:confused:
your 285s arent 33 inchs in height so yeah Ron has a point
I have 275/55/r20 = 32x10.80-20 and they are super close to the A arms, i have been thinking about some 1inch spacers just for piece of mind
Originally i was refering to
In which I said they do on mine ...
But after such...
Overall Diameter of 285/40R22 = 31"
Overall Diameter of 285/75R16 = 32.8" or larger depending on brand, tread, ect..
So the 16 is a bigger tire... BUT 285s Can fit
They don't fit with at least a couple of inches of lift and it's been proven many times. You can cram them under the stock suspension but they will rub and off road they will not work at all with the stock flex. I have the 265/75s on and they have less than an inch of clearance from the A arm and the lip of the fender flare.
Hmm this has turned out odd
What size tire do you guys run on 2.5 " lift? HOLLA HOLLA HOLLA HOLLA HOLLA Oh and show mw some pics of 2.5 inch lifts! Show em to me you know you want to!:biggrin2:
I am wanting to see if you can tell a difference w/ a 2.5" lift or not?????From stock to 2.5" up
Re: Hmm this has turned out odd
Oh my god I think I just threw up a little.........:sobbing:
