Can't Control Back Windows from Driver's
The back windows work OK using the controls in the back seats.
But I can't open and close them from the driver's seat. (You know, there are four levers there, two front two back.)
The front windows open just fine from the driver's seat.
I just discovered this yesterday, but I have been working out of town and rarely home the last couple of years.
(Of note, last month I had to get a jump from AAA at my house because my battery had gone dead. I can't remember if I even got a click from the starter but definitely no engine turnover at all. I can't remember if I left an interior light on or something ? So I don't know if that might have anything to do with it or not.)
I think Toyotas are well-known for window switch problems, however, last time I had this, on my Pre-runner, an engineer friend said to spray it with LPS electrical contact lubricant (LPS 1) and that did the trick.
I called my regular mechanic and they said it sounds like the master switch.
It sounds expensive.
Any thoughts on this ?
Thanks everyone, I love this forum, the generosity with your time and help is so very much appreciated by me, and by many others.
:angel:
PS, edit: I found this yt vid having to do with "normalizing" power windows, moonroof, etc., after disconnecting the battery for --not sure, more than just a few minutes?
https://youtu.be/zXAEQN7yegA?si=tG31frPvtHND2PKG
PSS: the vid above seems to be about getting the "auto" function of the windows to work, which is when you push the lever once and the window goes all the way down, or up too I guess. I just noticed that the front four switches in the driver's door say "All Auto" underneath them. Also that the back door window switches say "Auto". But the back windows are not doing the "Auto" thing. I played around with holding the switch down for a few seconds extra but no love on that. Ai yi yi looks like I'm in for an expensive visit to the shop.
Driver door switches still not opening back windows.
:angel:
