car shakes while in gear at a stop (auto tranny)
mtbdavid
Hi,
I have a 4 cylinder 96 4Runner with automatic tranny. When at a stop and in Drive, 1st or 2nd gear the truck shakes. When I put the truck into neutral or park the shaking, vibrating stops. Any ideas what the problem could be? Bye the way, the car does not shake or vibrate when moving in gear, only at a stop.
Thanks,
David
not to be rude, but your account has 3 posts...of which all 3 are the same cross posted to other areas...that's typically viewed as quite rude. pick an area and post once in there. most people view the forums via view new posts anyways.
don't have an answer to your question, but welcome to the forum! If you haven't already, you might also try using the search button to see if others have mentioned this.
Ciao!
Kevin
im not sure how the toyota xmsn works..but when i was a gm guy we had had alot of vehicles come in w/ those symptoms and replaced alot of torque converter clutch soloniods on the 700r,125 and 440ts..you could also check your flywheel and mount bolts to your torque converter..
there dosent seem to be alot of information on this forum about mechanical stuff...just alot of talk about tires , exhaust and little detail work...i posed a question about some top end work a while back and nobody had any answers for me..
peace
