Carbon Build-Up ... How to clean it out?
Arctic 4x4
I need to de-carbonize my engine. Its a 3VZ-E in a 90 T4R. I haven't done a compression test, but it sure feels like its lost compression.
I have heard that there is a bottle of something you can buy that flushes all that junk out. What is it, how do you use it, and is it the best way to de-carbonize?
Aight... did some Googling... discovered a little magic worker called Sea Foam.
Went out and bought a can... just sucked it into the engine via the brake assist line... and now we wait.
Here in the next 10 minutes or so I should be able to crank it back up and enjoy the carbon smoke cloud! :D
Will post results here. If it's anything like what I saw in all the YouTube videos, this smoke cloud will be HUGE and the truck should run a thousand times better with better gas mileage, smoother idle, and less noise!!
FINGERS CROSSED!!
Smoke cloud was big, but not as impressive as I thought it would be. The engine sorta sounds better... but I have to really listen for improvements.
Kinda wondering how well this worked.
However, one of the things I found while Googling earlier is that improvements are not always felt on the first run. We shall see. :)
Sea foam is some good stuff, but if your engine has alot of carbon build up, you might want to run some more sea foam through it in about a week or so, also pour some in your gas tank and it will help clean your injectors.
workingwheelswnc
