Here is a picture of the antenna mount I need to use for my 102" SS whip;
Mobile CB Antenna Ball Mount Base - RadioShack.com
I can get you the dimensions of everything if you need it since I have the antenna, spring, and mount already.
Thanks,
Doug
Whats this new mount you spoke of?
Just got my mount, looks great Drifter, plan on installing it tomorrow. So I'm pretty new to the whole CB thing and I have everything installed except the ant. to the mount.... My question is what do I need to have to secure the Ant. to the mount? My ant. is a firestick 2 if that helps, I really just want to do this correctly and not have this thing break or fly off down the road. Thanks.
I was hoping the firestick included everything but I guess not. Hopefully radioshack carries it, thanks for the help.
call and make sure first. I went to the one by my house and they recently stopped carrying CB related items. I had to drive another 15 minutes to a radioshack that did have it. it's like $8.
Thanks for the help guys ended up getting it from a truck stop in town, ill be going there for all my cb supplies as it was a lot cheaper than radioshack. I bought a SWR meter but can't get the readings to go below 2, its just hovering right above it. Screw at the top of the ant. Is out as far as it can go. Anyone else have this problem? Looks like ill be shimming the ant higher.
Just double checking,
did you properly ground the mount?
I'm glad your double checking cause I'm clueless. The only ground I did was for the CB. I just ran my coaxle cable like everyone else. Attached the mount, insearted the ant stud, mounted the ant. Viola. Is there something I missed? Ill be posting a pic later this evening.
