CB radios and mounting.
First, anyone else running the coax and ground through the tail light bracket...are you getting moisture in the light housing like this?
Nope! That's why I put my mount under the taillight. Water doesn't flow upstream into the light. :rockthrow:
With the way yours is, its too easy for water to find its way in. My $0.02
Hey guys. I want to get a CB radio, and I've been looking at some CBs and it seems like most people here decided to go with the Cobra 75 series. I want to mount the CB either in the console, or preferably the "secret" compartment above the glove box.
From personal experience, what would you recommend? The console mounting allows for easier access to the unit, how important is that access? Also will the 75 fit in that compartment in the glove box?
Lastly, I've been looking for a fold-able antenna mount that I can mount to the factory roof but haven't had any luck, does anyone know of a company that sells these?
Here is a good option.
hmm so you think the water is traveling down the coax cable and behind the light, thus creating the moisture that seeps into the light housing? I'm not sure I agree as I have some duct tape over the coax and top of the light housing that would disrupt the flow of any water but I'm going to take it off in the next couple days and see if I can figure something out. I was thinking it was more due to the coax bumping out the housing a bit (not fitting flush as it did before) but that is not unique to my install.
The housing should be airtight and I dont think running wire behind it would compromise that but I'll double check. It may have happened during install as it was fairly humid and I think one day it was a bit rainy so I might take it off and use a hairdryer to dry it out and then seal it back up inside. Either way, you got my thinking a little differently so maybe I'll figure it out thinking about coax causing water to move downward towards the light.
Thanks!
Toy2G, nice install! I think i read your install thread, can you link to it here for reference? What overhead assembly is that? Do you have a sunroof? Looks like you'd need to relocate the switch if you did that but it looks awesome!
Thanks!
Yea! I'm of the opinion that duct tape will fix anything, as long as it doesn't mind moisture. I think both humidity and bumping out the taillight (not sealing it with the body) will cause this fogging. I have my housing bumped out too, but I go in from the bottom, hopefully leaving any chance of water following gravity and the coax into my vehicle.
Glad I got you thinking from a different perspective!
My PA speaker came in today. Got it mounted beside the power steering fluid. It's all hooked up and working great.
It's 6 strands of ethernet cable, 8 wires each... I think it says there are 40+ wires, I still think it's an interesting idea and would allow a large cb to be mounted without taking up other useable space
It's a great idea! Just seems like a pain in the ass lol
Any disadvantage to an old Midland CB?
I jsut came across a NIB Midland CB in my parents house. (Model 77-882?)
Its even got a Midland Convoy Buddy Sticker and a slick ol trucker dude on the box!
My question is; is there a major disadvantge to this radio over the Cobra 75 or a Bear Cat for example (apart from having to manualy turn through channels)? I am not savy enough to know if there has been giant leaps forward in the past 30 years regarding CB tech...
Keep on truckin'!
Might as well mount it up and see how it goes...if you don't like it you can always swap out the radio. Mounting the antenna and running the wires initially are the tough part.
Keep on truckin'!
The older CB's tended to have louder output so you never know! I use my mom's old cobra CB from the 70's. It's awesome!
Sounds good to me.
The only drawback is that it is bigger and mounting will mean doing it on the on the roof.
I need to find or make a mounting bracket that swivels so I can twist it to face me when Im using it and twist it to the rear when Im not (so the missus doesn;t have to look at the CBs backend and wires all the time).
Sounds good to me.
Yea, that's why I run my Cobra 75 WX ST. Its tiny and I run it through a 100w amp, so I can be heard very easily haha! That's only like 25x the normal output of a CB :flipoff:
I was gonna get the 75 and then i came across this one! Im torn...
I could save the old CB for when I buy a Gen1 T4R. That would be a cool set up.
lindwlson982
