?Center Bore?
hdeuce22
I have a 2012 Limited and trying to determine what the center bore is on these. Can someone chime in and tell me? I'm getting ready to purchase new wheels online and I want to make sure I have all my ducks in a row. Thanks!
The hub bore is 106.00 but 99% of aftermarket wheels are lug centric although you might be able to get hub centric rings for them.
So as long as I get a bore of 106,I should be ok correct?
Yup but I doubt you'll find any as most aftermarket are bigger than 106 and the lugs center the wheel not the hub.
Here's a couple of threads with some info on hub vs lug centric wheels Here and Here
These are the wheels I want with the specs:
Fuel D530 Hostage - Chromel by Fuel Off-Road
FUEL D530 Hostage Wheel 20x9
Bolt Pattern 6 on 5.5
Finish = Chrome
Backspace = 5
Center Bore 106.4
MaxLoad 2200
Offset = 1
Finish = Chrome
Backspace = 5
Center Bore 106.4
MaxLoad 2200
Offset = 1
That'll work well for you. I'm a fan of the Fuel "Gauge" rims myself.
Yup those will definitely work well. What size tire are you going with??
I've been back and forth between 275/55/20 and 285/50/20 but I think I've finally decided on the 275's. The ratings for most of the 285's aren't near as good which is to be expected with more rubber on the road.
Yup good choice on 275's, the 285's might give you some rubbing without a lift. You also may want to consider those wheels in 20x9 -12 offset, these will give you a little wider stance and I think you'll like the look. Just a suggestion.
I've actually contemplated that as well. I do like the wider stance but I just wasn't sure I could go with the 4.5"BS without having to trim and cut. Are yours 4.5"BS and if so,did you have to mod anything to make them work?
