cheap hitch security
flyinbrick
I don't know if this is common knowledge in the towing world, but I thought it might be helpful ...
was looking for a locking hitch bolt for my new bike rack, but I didn't like that idea since that means yet another key to keep track of. They also are not cheap and seemed like a cost overkill for a $200 bike rack. The rack came with a 5/8-11 bolt that any crescent wrench can remove, so I simply replaced it with a socket cap screw. It was like $2 from McMaster and I needed some other stuff from there anyway. Now, you would need a 1/2" hex socket to remove it.
lol the only problem. all the other nuts are crescent wrenchable, like the 4 I see in the picture glaring at me :)
Don't lull yourselves into a false sense of security. These options only keep honest people honest. I lost the key to one of mine and found it to be scary how easily I popped it off.
All it took was an 18" piece of pipe slipped over the lock and a couple of rocks back and forth----snap! These things are made to be hard to cut through which makes them extra brittle.
Doh! :ybrick:
OK, you're right, but, here's how I see it. First, you have to undo four bolts. Even then, you won't get the piece that goes into the hitch. The purpose is not to secure the bikes - just the hitch. I would think that if you can't steal the whole thing, it's not worth stealing. I suppose I can change all the others to hex caps too, but at this point, it's not worth doing.
no one steals hitches, they steal what is attached to it :)
4 bolts is nothing when the item attached to it is a $400+ bike.
These are the bomb, and not at all expensive: Amazon.com: Trimax TAR300 Anti-Rattle 5/8" Keyed Receiver Locking Pin System: Automotive
The anti-rattle feature works well, and I just leave the key in the glove box of whichever vehicle the hitch happens to be on.
I have seen too many of the keyed style get rusted and froze up. then you cant remove it without cutting. no thanks.
I prefer a bolted hitch pin, similar to the OP's. though, mine is a standard hex, but its a large hex and put on very tight. nobody will be unbolting it with a standard/small crescent wrench.
also, I love have a hitch or accessory that doesn't move, rattle or vibrate. its really the only way to go.
maybe its regional? I know a lot of people get their drop hitches stolen. they are expensive to replace. a $10 anti-rattle bolt is good insurance, and makes for a more secure load.
only good part, when its freaking cold no one just randomly walks around to steal stuff around here.
and a 10-15 min steal job gets awfully dam cold with your trying to steal something at 0F or -20F.
I am thinking of changing out my hitch screw shackle for winter for a hitch hook for my tow/snatch strap. too much hassle when its cold and using gloves getting that screw pin out to hook up a rope.
I currently have the regular shackle pic # 1 but would pic # 2 work or is that a weakness being bolted compared to pic # 3 where its all 1 piece.
for safety reasons, I recently switched to a shackle on my winch also. hooks are OK for a quick, and light extraction. but they can be dangerous..
well I would only use the hook for quick/easy snow removals.
its just that the shackle has a tendency to freeze during winter where its a job in of itself to unscrew the bolt.
Leave the shackle and pin in your glove box. :thumb:
Any of the three receiver mount recovery points you posted will work fine. The bolts in the second one are not a weakness, that hook is no different from the factory recovery points on millions of SUVs and every one of them is attached to the frame with bolts.
:iagree: Unless you have the JBL rear speakers, use the right side storage area in the rear to keep the draw bar in until needed. I wrap mine in a mechanics rag so it doesn't rattle around too much.
in the winter time I just leave it on all winter and break out the rope as needed.
hence the reason of going to the hook for light recovery's and the shackle for worse situations.
044runner4
