Check my wiring diagram?
jangoforhire
Alright I just finished my wiring diagram for my lights (Rack should hopefully be here next week!) and switches. It's been a while since I did some wiring, and I have an interesting setup here with two switch panels AND an override (protective) switch for both panels.
So here is a link to my diagram (it's a link because it is a BIG image, so wait patiently and use that ZOOM tool!):
<a href="https://dl.dropbox.com/u/58059700/4Runner/Build/Wiring/Wire%20Diagram1.jpg">DIAGRAM (large)</a>
If you are wondering what you are looking at, the battery is at the top, the two boxes wired to the battery are two wired wagon fuse/relay boxes, and these connect to the two 6 switch holders (bottom left), which then connect to my Rigid Lights (far right). I know I did leave some stuff out, like the fuse box and battery ground, and fuses for the fuse/relay box, but that's just because I was lazy and these diagrams are a pain to do in photoshop.
Basically, it should work as follows:
None of the switches turn on the lights until the main switch is turned on (the far left switch on both panels). Once that switch is flipped (on either panel) both panels become hot and all the switches will now work to turn on their respective lights.
Hope this isn't tooooo complicated, but does everything look ok?
Thanks guys.
Thanks! It took a while, but I wanted to have a universal diagram that I can keep for a while and add to it when I need to.
Looks nice Jango, but I'll have to wait till the weekend before I have time to review. Hopefully someone will beat me to it so you can get going.
Okki
Are you planning on cutting the wiring harnesses off the Rigid lights and using your own wires to go in to the WiredWagon fuse blocks?
Yes I will be cutting off most of the included harnesses. I will leave the waterproof quick-quick that is close to the lights. That's probably about it though. I've got like 5 spools of 100ft wire from amazon sitting around here somewhere so I'll be good there. Just lots of heat shrinking and crimping.
Okki
Thanks Okki! I'm pretty sure everything is good. I just want to make sure I didn't overlook anything. So far no news is good news.
4Runna4Rumma
