Choice of Gear Oil
Urbanite
I'm getting ready to change my rear differential oil and was wondering if this would work? If I buy 7 quarts, it's free shipping and would be enough for 2 oil changes.
85W90 Hypoid Gear Oil - Liqui Moly LM20010 | FCP Euro
Also, locally someone is selling Toyota factory's gear oil for a great price, but it's for an LSD and mine is not. Is it OK to use LSD gear oil in a non-LSD differential?
The rear calls for straight SAE90 gear oil. Its kinda hard to find in stores so most people just use 75w90 which is the same for front diff and transfer case. Not sure about the 85w90 for the rear.
I use Mobil 1 75-90 in front and rear diffs. I buy it at Walmart they have the best price. You need I believe 5 quarts for front and rear. T case I run the Toyota stuff.
Maybe someone who has used the products you linked will come in.
The oil you are considering says for transmissions that require Gl-5. Doesn't mention differentials. I would stay away from for diffs.
LSD gear lube fine in non-LSD.
Interesting. My manual says 75w90 for the transfer case :noidea:
Yeah, I’m just paranoid. Plenty of people run the Mobil 1 75-90 in all three (both diffs and tc) with no issues. I’m up at 165k so just weary of replacing it with something new.
That being said I’m a weirdo that runs all Toyota fluids for everything, except the diffs lol.
This is the right stuff for rear diff, cheap and could last for a long time (5 Gal). But never heard of this name:
GL-5 SAE 90 Heavy Duty Automotive Gear Oil - 5 Gallon Pail (18L - 4.75 GAL) - Walmart.com - Walmart.com
EDIT: I searched for manufacturer (SINOPEC) and it looks like this is a Chinese state owned company. Would you use a Chinese fluid? I know everything is now made in China, but with fluids I'm a lot more conservative.
I wouldn't use it, personally.
There's really no reason not to use the same 75w90 gear oil in the rear that you use in the front and tcase. Unless you get different gearing and/or a locker and the installer tells you to use something different that is specifically required by the gears/locker.
Probably completely overkill but the rear diff is a weak point so why not,
I have been using Redline HD shockproof for the last 15k of offroading and road tripped miles with great results. Changed it recently and it came out looking as good as new.
I used the amzoil version because you can get it in collapsible quart containers so I don't need a pump to put it in.
Edit: This was for my 5th gen, 75w 90.
I used Vavoline 75-90 non synthetic. I plan on doing it again at 70,000m miles as it's a simply job.
Synthetic is so overrated. Conventional nonsynthetic Valvoline was all the parts store had .
three quarts and you are done in 15 minutes.:roll::roll:
CaptSolo or CaptF150? All you need to do is get some quality synthetic oil to stop all of your oil leaks. And some proper WS for your WS transmission.
150,00 miles on my 15 year old transmission - always serviced by the dealer with T-IV (not WS). You own a dealership? are you a mechanic?
Why waste money on expensive synthetic that is 10%, when convention gets changed every 60,000 miles, has better viscosity, more history?
BTW All my oil leaks are almost entirely stopped by switching back to conventional motor oil on a 15-year old 4 runner.No more synthetic in old cars says Scotty!
Scotty Kilmer says same things about synthetic. You like leaks, use it.
Scotty Kilmer - 53 years a mechanic. Has his own television show. You?
Where do you work. What's your NW?
Scotty Kilmer is a millionaire. You?
This quickly degenerated into a Scotty Kilmer groupie love letter
Valvoline 75w-90 full synthetic. Never failed me!
I wanted to go with Amsoil all around but the budget for for updating all the deferred maintenance of the PO made me rethink it. I went with ^ Valvoline full syn for diffs and transfer case. Bought it online at advance auto with 20% off coupon and free delivery.
if you used 75/90 it was SYNTHETIC captnsolo... valvoline & most other brands dont offer conventional in 75/90, 80/90 is non synthetic. can you post a link to 75/90 non synthetic valvoline please?
Grease & Gear Oil - Valvoline™
2005 4runners use WS for the 100th time captn.
synthetic is 10%??? where'd you come up with that?
more of your trademark scotty fanboy crap... he uses STP synthetic in that video of the high mile toyota, so apparently scotty doesnt do what you claim he does.
nobody cares what his or your net worth is captn. please stop.
still waiting for a link to this non synthetic valvoline 75/90 gear oil...
& any shred of proof that synthetic oil or gear lube is "10%"....
