Snowy21
I know it's a really small update but I think it will contain useful info for somebody contemplating rear diff armor
I was worried about inadvertently backing into a rock and ruining a day out on the trail so I decided it was time to armor up the rear diff
I bought the Trail Gear large diff armor from FROR even though it only listed fitment on 86-95 axles. I had to cut my non functioning parking brake cable at the bell cranks, then cut off the mounting bracket that is centered on the back of the third. I had to cut the bottom half of the bracket that holds on the main parking brake line to clear the left side. That cleared everything away on the axle and all I had left to do was cut about a half inch off the back side of the fill plug tube so that the right side would seat all the way down. Only took about 30 minutes in total to get it fitted with no directions. I've got an automatic trans and my parking brake hasn't worked in at least 5 years so it won't be missed
Did the typical wire wheel the axle, por15 the center and then sprayed everything once I was finished.
