Clunking on driver side over bumps?
I know this is a rather old post but I'm having the same problem on the driver side. Anyone ever figure out this annoying clunking noise??? Please help lol
remove the sway bar. you will never have this problem again.
Sent from my SM-G930T using Tapatalk
Had the same thing. It was my swaybar end link's bushings. Replaced the bushings and the clunk went away
Sent from my Pixel 2 XL using Tapatalk
I've had the same problem for a long time. My LCA's needed replacing so I asked my buddy to see if he could figure out the clunk sound too. He did. As others have said here, it's the sway bar. In my case, the sway bar actually taps the spring at full compression but it's because the sway bar bushings are worn. Hopefully, with new bushings, the sway bar won't hit the damn spring. (Only happens on driver's side.)
Clunking/popping noise
Been dealing with this same problem for at least a year, went to 2 different off-road shops and they both said everything looks fine. One suggested might be the ball joints but he didn't seem too sure so I got another opinion. My usual mechanic suggested to change the lower control arms, he showed me that it's cracked and lose so he was sure that's where the noise was coming from so I believed him since he offroads a baja style built tundra. After changing the lower control arms I'm disappointed to say that the noise is still there though not as bad as before but on bumps like my driveway definitely still pops. Anybody figure this out?
Ambrose67
