CO2 Tank Stored on Roof Dangerous?
When was it last pressure tested? That testing certifies it to heat well in excess of the summer sun. I think if the cert is current you have nothing to worry about.
Thanks for the quick replay man! Don't quite remember, but I'm pretty sure it's currrent b/c I swapped it out at Airgas.
1 major question?
Do these have bursk disks on them to protect them from overheating?
If they do, keep it inside. Ever play paintball? You loose a burst disk, there goes all your gas.
If they don't have a burst disk, then I would still keep it inside. Wouldn't trust it in the sun like that...
If at all possible you never keep a compressed gas tank inside any closed vehicle.
Yes, certified CO2 tanks come with a burst disk, but if that went off inside your car it would be a frighteningly loud POP and instantly flood your interior with CO2 which is HELL when it hits your eyes, nose and lungs. It could be pretty ugly if it happened while driving.
Now normally heat alone would not cause a certified and properly filled tank to vent, I see them stored in the sun full all the time, but there are a lot of stories out there of tanks being improperly/overly filled and those WILL vent with very little provocation, so the roof is definitely a lot safer for you(Assuming it is WELL secured up there, that's a lot of weight when full!).
Thanks for the info guys. Yeah, I was worried about the possible bursting inside the vehicle also. Figured it's better to keep it outside in the off chance that it does go off.
ive seen many burst discs randomly pop. they are independent of the tank certifications. sometimes they are slightly weaker, or just old.
the extra pressure from the heat may be just enough to cause a problem. I think I would wrap it with something to keep it out of the direct sunlight.
If you keep it in the truck, keep the back window cracked and you'll be ok. It'll be scary as shit(either way, inside or out), but that crack will keep the CO2 from killing you.
1 major question?
One of my friends has run his CO2 tank in the sun for years with no problems. I stored all kinds of tanks in direct sunlight, O2, Helium, Argon, and CO2. I never considered them a problem, and I still don't. Now if you are using a paintball gun for your tank, better look in to it.
increasedc
