Compiled: FJ Springs Lift Info for 4th gen
double check measurements....
I'm looking to add a little lift and get the back about an 1 inch higher than front and would like a second opinion on my maths. I currently have .85 on bilsteins up front and fjs all around, but my rears only have 3k while the fronts have 80k.
I measured my current setup from ground to top of wheel well through wheel center:
Front: 35
Rear: 36.75
So if I bump up from .85 to 1.75, I'm adding .9 inches, but it will add 1.8 inches of lift with the front trig factor, putting the front around 36.8. So, to get the 1 inch rake, I'd be wanting to add a 1 inch spacer then in the rear? (Or 1.05 to be precise)
I'm hoping to turn my silver into something like PharmSCRunner's below who has FJs and Cornfed 2-1.
Front: 35
Rear: 36.75
The lift height advertised by Bilstein is the net amount of lift you will gain. They may not be exact, but you will not get 2x their stated height. The actual grooves on the shock are approx 0.5" appart, so each notch up should net approx 1" lift.
That said, once you figure out the front, you can order a custom sized spacer for the rear from Cornfed. I've ordered a few from them in custom sizes for different setups I've ran.
Front: 35
Rear: 36.75
Go to the Lift and Tire central sticky and find my post from a few days ago, I have same setup as you and was looking for the same thing. I posted pics of my ride at various levels front and back. My advice would be to just put your Bilsteins at 1.75 and put the Daystar 1.5" spacer in back. That's what I'm rocking now and it looks great. As the other poster said, going from .85 to 1.75" adds an inch not double. Those Daystar spacers can be bought on Amazon for $38 + 2day shipping rather than $100+ for custom. The rake ended up perfect. When I have it loaded down for a trip or towing a trailer it'll probably sit nice and level.
Does anybody know how much lift it takes before your alignment is thrown out of spec? Will any amount of lift require a new alignment? Considering a small lift with FJ springs and 5100's set at .85".
Any lift will require a alignment. If you mean how much lift before you cannot align it with stock arms and such,I think the general saying it 3". Although, I have 2012 FJ Trailteams springs with 1" front spacer and 1.5" rear spacer and the alignment shop could not get everything to spec. I think the caster was about 1/2 degree out or something. I do not have my sheet in front of me to check. It was nothing to worry about though.
FJ/Bilstein 2-2.25" (F) 1-1.25" (R) Lift
Vehicle is a 06-08 SR5 4X4. Im anticipating the lift will be a combo of Bilstein 5100s and FJ or OME 884 coils up front and 5100s and a combo of FJ and maybe OME 895E rear coils.
According to the Bilstein web site the 5100 perches are spaced 5/8" or .625" apart. So using the OE coils bottom #1 = 0 lift, #2=.625 lift, #3= 1.25" lift and #4=1.85 lift.
Assuming a .75 - 1.0" lift from the FJ coil alone + the #3 perch should yield around 2 to 2.25" of lift up front.
In the rear the FJ coils yield an average of .5" of lift which means i'd need to add a 1/2 spacer or possibly cut down a 1" spacer to 3/4 to get 1 to 1.25"s of lift in the rear. Or just buy some 895E coils and be done with it.
So does this sound right? :infidel:
Bilstein 5100 shock perches are 0", .85", 1.75" and 2.5" of lift. FJ coils give 1/2 - 1" of lift depending on 2wd, 4wd and V6 or V8. Also depends on how much your stock coils are sagging as to how much lift you'll actually see. I got over an inch of lift in the rear with fj coils because my stock springs were toast!
Very helpful information! With that in mind, here is my plan:
Current setup: Passenger front: 35, Passenger rear: 37
Driver front: 34.5, Driver rear: 36
I am definitely of adding one inch to both fronts via the bilsteins, then a 1/4 front spacer (I have one lying around anyway from Wheelers) on top of the driver side, which should put them both to 36.
Then for the rear, a .5 inch spacer on the passenger side to get it to 37.5, and a 1.5 spacer on the driver to get it 37.5.
This whole production should* give me 1.5 inch rake and correct the driver lean. Or I could just throw a 1 inch spacer on both rears rather than try and mess with the lean as I didn't notice until I measured.
FJs and 5100s all around here. They in a daystar 1.5 spacer on the rear driver and seems to be level all around. Fronts set at 0.85 setting and seems to be 35 front 37 rear with 265 DTs (I know that's not the proper way to measure, I just did a quick walk around yesterday after throwing the spacer on).
I picked up a set of tacoma TRD offroad (progressive) springs last week and will try those out when I get time to swap.
I too have an extra daystar spacer amd OME rear trim packer for sale if anyone needs one. Will throw them up in the for sale section soon.
Just Curious
I contacted a local body shop/ mechanic shop, that I have been doing business with for a long time and see them as very honest about their work. Now the price is higher than most places but the quality is second to none.
I am looking to put on the FJ coils with 5100's, I'm not mechanically capable to install it myself, I don't have the tools, (spring compressor, air guns, etc.) to handle the install myself, nor do I have any record of mechanical work, other than the changing of tires, oil, and other small feats that everyone knows how to do.
My question is, how long does this install take? My mechanic said it was a 6 hour process and would cost $500 alone just for the install? Is that a decent price?
Seems legit to me. I think I could do it faster but I've done it 5 or 6 times now. I don't have a lift or air tools. Price seems good to me for the amount of work.
That is a Fair price, i was in the same boat and found someone that did it for $500 (I brought my own parts) and Also removed XREAS and converted/removed my RAS
really [MENTION=101553]t-man[/MENTION], you think so? i guess i am a bad judge of timing, but i would think 3 hours, at most 4 for the work.
granted, like t-man, i have worked on all kinds of tacoma and 4runner front ends over the years. i did my fronts with the no spring compressor method in under 1.5hrs on the front and the rear was done in under an hour?
too bad your not local to denver, i would do the job for $200 in my driveway!! and im a professional...
I was figuring them looking hours up in a book and not really working on our platforms before. The first time I did mine it took me like 8 hours, but I had some issues and frozen parts to break loose. Lol. Now, oh Ya I could crank that right out! I'm actually going to be doing new shocks and coils Friday night for the offroad event on Saturday. I figure about an hour per side.
Are people still finding FJ springs to be readily available or are more people moving towards the Moog springs? Are people still having fitment issues with the moog springs?
I have an 06 4Runner, i need up to 2009 FJ springs or has it turned out that the later years work too?
I read most of this thread but the early part is a few years old now... and my XReas is getting bad...
Thanks for all help!
Chris
Chris
From what I understand any year will fit. I found mine at a junk yard and talked them down to $50 for the pair with the center cone bumpstops thingy.
wayblom
