Read the tire rubbing section of this page. 265/70/17 is the same size as what you're asking about. The bfgs may have more rubbing, but running fj wheels and not spacers should help. That'll give you a very good idea of what's needed.
Toyota 4Runner Wheel Spacers
So I am looking at getting a set of 2011 FJ springs and then getting a set of 5100s all around.
I am thinking this should give me about 2" of lift in the front and .5" in the rear.
Do you think I would be able to fit 285s down the road? or will I have to throw top off spacers in? I already have 1.5" wheel spacers. Thanks guys!
Ark,
You are the man. This is pretty much exactly what I am going to do. I just got 2011 FJ springs from the FJ forum for $75 shipped, going to buy new 5100s and throw them all around with the 1.5 daystar in the rear.
The only thing that sucks is I only have about 6k miles on my current tires. May hold off on the rear spacer and set front at .85 until I can upgrade tires. Or you think I should just bang out the 1.75 setting on the front right out of the box? I have the v8 with push bar and roof rack
Anyone know which Daystar kit to use if I am going to swap my XREAS with the 2010 FJ bilstein suspension? Would it be the 9115 (for 4runner) or 9124 (for FJ) ?
ARK: thx anyway, I guess i'll order them both and see what the diff is. Any updates on the swap chart ? I'd like to know how much lift I'll get with the bilstein shock/spring setup without the daystar. If it's enough then I might just forget about the DS.
Is there a difference between 2010 FJ springs and 2007 - 2009 FJ springs or is there just a difference in the shocks given those years?
Both are a direct swap, but I've heard the 2010+ are a little beefier that the earlier ones.
So I can run 2010 springs on the 07 - 09 shocks? Thanks for the info.
