Corner LED's
subzero
Has anyone experienced problems with replacement LED's for the corner of the headlight fixture? There was a thread around a year ago about replacing the stock orange bulbs with a star patterend 5 LED fixture. I successfully replaced the bulbs with the LED's, only to have both of them burn out within a month. If anyone has successfully replaced the orange bulbs with some type of LED, will you post a link to the ones you have used.
Mashimaru said:
i've got the 5 led bulbs in mine, about 2 1/2 weeks on them. got mine from superbrightleds.com
Had a set from superbrightleds fail after about 6 months.
Yea thats where I got mine. They did not last long. Be ready to find another set!
any of the 194/168 bases should be able to fit. There's one that has a heat sink within the casing so that could be a possible try for the corner lights. As for my leds i know those don't go long as those are my 2nd set, my first white ones lasted me almost a year (lucky i suppose) so i switched them to the 5 led ambers now. Anyways here's the link to the 194/168 autoillumination listing.
168 leds
168 leds
Cool, thanks for the help. Ill probably just go ahead and order 4 just to be safe.
subzero said:
Do you know exactly which ones work on our trucks?
I have these ones:
I made my own, and one finally went out last weekend. Last about 2 years, I used some cheap ebay LEDs. When I get some time going to make another one.
Another problem is, the heat from the headlights shorten the life the LEDs. So if you live in a climate that is hot to start with, then you'll have an even shorter life.
MikeV5280
