correct part numbers for energy suspension sway bar bushings
2k1
I am wanting to replace my original sway bar bushings, but do not want to get greasable bushings because I do not want to have to grease them every 10k...
First off if someone can enlighten me, is there a reason I should go with the greasable type as opposed to the non-greasable type?
Secondly, I know the measurement of the stock sway bars, so I am assuming but just double checking, I suppose, will these parts fit:
Front: 1" / 25mm energy suspension part # 9.5129
Rear: 3/4" / 19mm energy suspension part # 9.5123
energysuspension.com | Sway Bar Bushings
Black 9-8105G
Red 9-8105R
I also make links if you're interested, and these are the bushings I use.
Mike
thanks, but I am looking for the D-ring bushing part numbers for the sway bar, not the end links
I already replaced my end link bushings with those. so no need for the entire kit or new end links.
I just needed to ensure the 1" (25mm) fit the front and the 3/4" (19mm) fit the rear...I know those measurements fit in the greasable bushings, just wanted to be sure they fit the same for the non-greasable bushings.
pax at 4
