Craigars Soft 8's Yay or Nay, And Rim Size?
Spencer
Steel but only 65$ a peice will I regret it?
attachment.php
And what is the lug pattern of a 97 4runner and offset of a limited 4 runner? I know my limited rims stick out a good bit and Id like to keep it close.
Get 'em! they are good, you will be happy.
Lug pattern will be the same for the 3rd gens just make sure its bigger than a 15" diameter.
6 on 5.5 is the bolt pattern. Stock rims are about 4.5" backspacing. I'll bet those will come in 4" BS which would stick out about .5" more than your stock rims.
i wanna get the same for my 98 4runner lmtd. where are you ordering from? i wanna make sure i get the right ones
I see some with 5" back spacing.
Are you sure there all 4.5? I thought limited would have less because of the fender flares. Once I removed my flares my tires stick out a GOOD bit.
attachment.php
YESSSS!!! Mine just came in last week and I also got a pair of BF All Terrians and they look amazing!! i am putting them on my truck sometime this week. I have a 2000 limited black. It was suchh a good decison, i dont regret it.
AFAIK, the stock rims range from about 4.3" - 4.6" BS'ing depending on style. And yes 8" is good for 31s - 33s. 5" BS'ing probably won't make 265s rub, but will definitely make 285s rub (on the control arms) without .75" - 1" wheel spacers.
