crazydubman
Active member
You can see in this picture that there is no way with the Camburg UCA's to even get a 1/2" of turn on the wrench with the suspension fully drooped out. I tried to jack up the hub enough to get a wrench in there but it puts too much preload on the spring and I can't turn it.
I may have been ok with stock upper control arms but There is no way I can get in there with the Camburgs. Thats why I was thinking of swapping to a 14 inch spring to get a little more accessability. Hell if i went with installing a new spring I could always look into a 16" and back the collar off all the way so that it would have about 1.5" of preload on it from the start.
I figure un bolting the UCA is the easiest option. Only takes a few minutes with a box end and ratchet. you don't have to press out the bolt like you do the ball joint on the stock arms so its way easier.
Oh and the easiest adjustment mark that is already on there is the allen set screw.
