Custom "ABS OFF" Switch
erpcayne7
I'm sure some of us have been off roading and maybe been frustrated by the VSC system kicking in during use. I have lately been disconnecting (the gray wire) and have had better off road experiences than with VSC enabled. However, I'm not sure if that has any negative effect on my vehicle (disconnecting the gray wire was recommended by another T4R.org member [thank you]). But, since disconnecting the wire provides a whole different off road experience, I was wondering if anyone else has been able to connect this to some sort of OEM switch, a lot like the center differential switch, or the RSCA OFF switch found on the left hand side of the drivers cluster.
Anyways, has anyone else been able to do something similar to that or have any advice for that?
+1 for GrantK's post, but another benefit of being able to turn the ABS on and off is (when it's off) it keeps the ECU from applying the brakes to wheels losing traction (like a rear locking differential would, except without the benefit of not having to lose power). I suppose this might be a mod that be beneficial in place (I know it's not as good) as a rear diff locker.
4Runna4Rumma
