Custom rear seat usb chargers mod!
You da man thanks for posting! Should have came that way and I should have done this along time ago.
Bobby
Just a little mod I did today. Will be for a future video as well haha. I ended up adding dual usb chargers for each rear passenger. I wanted this to be oem looking by keeping it somewhat hidden but still easily accessible. The best spot I found was in the rear door panel within the pocket. I centered both and then used a dremel to cut out the holes for each charger port. My goal was to avoid having to run wires through the door grommet so I began looking for a 12 volt source in the door. What I settled on was the main power white wire for the positive and then the center green wire for the negative. All connections were soldered and the in line fuses were retained. I also made quick disconnects for both the keep things organized. Now both rear passengers can enjoy USB connectivity for their devices!
matisgugle
