Cut a hole in my front fender liner -- bad idea?
rjfowler
More background is below, but basically I just cut a hole in the front driver-side fender liner where the tire was rubbing at full lock. Does anyone think this is a bad idea? Only thing I can think of is that when it is raining the tire may throw a bunch of water in there, which is where the fog light housing is I believe. The hole is about 1.5" wide by 4" tall or thereabouts. Thanks in advance for your help.
Background: A while back I installed new wheels (18x9 -12mm) and tires (265/70/18) on my LTD and had some substantial rubbing. I just had installed a Toytec spacer lift (2.5" in front and 1.5" in back). It was still rubbing (but not as much) so I removed the plastic pieces at the back of the fender (see below). Then it was still rubbing a little bit, so I cut the hole in the front fender liner after moving it forward didn't do the trick.
Here is the truck with the lift installed:
These are the plastic pieces at the back of the wheel well that I removed (I had already tried cutting a hole in one of them where the tire rubbed):
I tried that, as well as moving the fender liner forward per the sticky. For some reason the driver-side front fender still rubbed.
Hi rj,
If you are concerned about that you could always go to Home depot and p/u a small piece of plastic or sheet metal and "JB weld" two part epoxy, and bond it to the outside of the liner to prevent water/debris from getting inside where your lighting is... just my 1.5 cents! :noidea:
The OEM light housings are sealed pretty well. I submerged mine entirely on more than one occasion without any water ingress. You'll be fine.
It's fine. Mine had similar cuts, even after pulling them as far forward as possible, using the heat gun, etc.
I tried using heat gun and moving liners forward on mine also. Still rubbed finally just got pissed off, and cut a bunch off. No problems so far.
