D Farms
after a wheeling trip the other day the outer ply of one of my balding tires cracked open. I ended up having to put the spare on. so im finally getting new tires, specifically the bfg ko2 in 315/75r16. I ordered them from the local 4wheel parts, along with a warranty that actually covers going offroad, and i dont have lie about it. they had one in stock and had to order the other 3. with all 4 tires, mounting, balancing, the warranty, minus the rebate it came out to about $1100. not bad for 35s, and good ones at that. I had them mount the one they had on the wheel i had to take off, which is perfect since I needed to clearance my wheel wells anyways.
When i put in my poly bushing a few posts ago I cut and welded my ucas to clear bigger tires. so I went to put the 35" on and it cleared the uca, on a stock 16x7 wheel. unfortunately the tire was actually touching on the spindle... so I reluctantly ordered some wheel spacers.
last night i stayed up cutting and welding up my passenger wheel well, and it easily clears a 35"or maybe even a 36". I will say a big hammer can do a lot of work, but there were certain parts that were reinforced and had to be cut. I also hammered after I cut and it was very effective.I put the truck on jack stands and took the coilover out. I then put the 35 on and jacked it all the way up and compressed the bumpstop as much as I could, and turned the wheel left and right. as predicted it rubbed the pinch weld and a lot of the inner fender wall.
so I marked with blue tape and cut it out with the angle grinder. Its not nesessary to make the cut that wide, but it helps to go deep after a wheeling trip the other day the outer ply of one of my balding tires cracked open. I ended up having to put the spare on. on the bottom I cut all the way back to the first bolt hole and then curved the cut up and terminated the cut at a sharp angle in the sheet metal(hard to explain unless you are looking at it). then I cut along the inner fender wall to make a sort of triangle shape. once i had cut it, me and my bfh went to town and I was able to pound the entire fender well out where it might rub. after I was satisfied, I bolted the tire back on and jacked it back up and turned the wheel left and right. It cleared the back of the fender but the stupid windshield fluid resivoir was in the way. I removed the windshield fluid resevoir and relocated it into the engine bay, just had to move a fuse box over a bit and the fluid lines were right next it anyways. Once that was done I checked again and now it was rubbing the front still. this part was a double reinforced sheet and a lot more difficult to bend. out came the sledge. checked again and it was good, about 1.5"+ clearance all around, keep in mind i havent put the spacers on. after that I plasma cut some 16 gauge steel to cover what i had cut and welded it in, only starting one fire in my truck... ill need a new passenger door plug, shit got melted. it took about 3 hours to get to the point where I was welding, minus the windshield washer relocation. welding it took a lot longer, the sheet metal was really thin, and im used to the thick stuff. anyways it came out clean, and I was able to keep hammering it too, so If I decide to modify the bumpstops or something to get more up travel, I can.
Next Ill need to do the drivers side. and figure out what im going to do with my fenders.
My spacers come in later today and the other tires might be in on monday.
In addition to all of this, I got $57 dollar light bar, 32" 180watts, I plasma cut a hole and mounted it in my bumper, should look clean once I finish the pocket for it. also the bumper needs to come off and you need 3 wierd allen keys to remove it, so it probably wont get stolen. anyways its bright as hell.
I also got chevy blazer bump stops, I cant say how I like them, but they are longer than stock and softer too haha. $2 a piece. also got the emblem off an 80s 4wd Tercel thats going to go into my grille. It looks bad ass and Says 4WD in big letters.
