initial alignment resulted in a very twitchy ride but after I took it back and told them to max out the caster (2.1 a side was all I could get) the steering is much more manageable. Overall extremely happy with the results and the writeup here certainly made for very smooth sailing.
Hey All,
Im an idiot and forgot all the pics to this write up were attached to my photobucket account, which i deleted a while ago.
I apologize and will try to put this back together or just post a new one
Rich
heres a couple old ones that may be of some use. Daystar (Spacer) installation on 4Runner with XREAS - Toyota 120 Platforms Forum 2007 Toyota 4Runner Sport Edition Lift
Thanks for this thread! Just installed the 2.5Front/2.5Rear Daystar kt09124bk on a 2005 Limited V8 XREAS. I read this thread first but like a lemming decided to follow the daystar instructions. Big waste of time!
Definitely disconnect the LCA if you are putting a 1.5" spacer or higher in up front. It might not be necessary with a non-XREAS shock or a 1" spacer but trying to baby that XREAS tube and jam a 2.5 spacer in without the LCA all the way down is damn close to impossible.
I had air tools but ended up using a breaker bar half the time. Front took me about 4 hours. Rear took 1 hour. Two people was definitely helpful when aligning the LCAs.
Additionally I opted to remove the front sway bar upfront. Read up on this and consulted a mechanic. I found that it really improved the ride quality. My wife was complaining about how rocky the 4R is compared to our old Lexus (she gets car sick easy and Seattle has a lot of bends). After driving it yesterday she said she likes how it handles now. I'm not a mechanical engineer but have a few in the family, the consensus was that the sway bar + XREAS is probably too excessive in transferring pressure to the other side of the vehicle both front and rear.
Did a couple other projects while doing this. Installed 1.25 wheel adapters and baked the headlights to paint them a gunmetal color. If anyone wants pictures on any of that or further details let me know.
One last note...I bought the lifetime alignment at Firestone. Had it on a Lexus previously and it is definitely worth it. Its frequently on special for approx $159+tax-where-applicable. About the cost of two alignments. Figure my next set of tires and a full icon or toytec swap next year will require at least two more.
Once again though. THANK YOU FOR RECOMMENDING THE LCA DROP!!
id love to see it! I have the DS lift and im about to put in spider trax spacers. I didnt find the need to loosen the LCA bolts, but I had a few friends and a lot of pry bars.
working around the xreas is a huge pain.
I was hoping for a 2 hour install, it took me 4 hours even with impact gun, shop hydraulic jack, air ratchet, ratchet wrench, and plenty other useful tools.i followed the given instructions except on drivers side I had to remove the shock to insert the top 3 bolts into upper perch because the angle wasn't allowing it to go in. I had a bit of trouble on both sides getting the bolts that hold the lower control arm to the bottom of the ball joint, took me about 20 - 30 min each side. otherwise the front went as planned. the rear wasn't as easy as mentioned by others, and I don't know how you did it with prying. I used a spring compressor. this was definitely a two man job, and I wouldn't advise trying to tackle it on your own. I didn't get measurements prior to lift, but will get some today post lift.
I definitely needed my brother on the other side to wiggle that axle. For me it was unbolt shocks (from axle), sway bar (from frame) and track arms (from axle). But I agree, two people for that.
Dang, just got got my Daystar from Amazon and was hoping the pics would have been restored to this post by now. No such luck. It seems like the most helpful thread out there, after having searched for hours.
Wish me luck!
