Decided to take my drive seat apart..
Tommygun
This past winter, I noticed the seat heater was getting extra hot, and the seat was becoming lumpy. Decided to pull back the cover and find the problem. Well, I found it...
Sent from my SAMSUNG-SM-N910A using Tapatalk
Holy hell....
2014 TEP w/ KDSS / Bilstein 5100s (front at 1.75) / Cornfed 1 inch rear spacers / 265/70 Nitto TG G2s / FN Cntrsteer Type X / RCI Front skid / Yakima Cross bars / NFab Steps
Yes, it's a faulty seat heater. It actually burned through the seat foam and has left a divot in the seat.
I called about it being covered under warranty and they said no. I'll have to replace the entire seat bottom, with new foam.
Either out of the warranty period or because he took it apart.... that's what I'm thinking.
That's probably exactly what they will say, but if he didn't take the initiative to take it apart, how else would this have been found?
If he didn't take it apart and find that, they would have claimed it was "wear and tear"
[MENTION=135467]Swacer[/MENTION],
1.) The tech could put a meter on it to read load resistance & determine there was too much resistance thereby finding a bad coil.
2.) Not if it was still within the warranty period.
Smarter thing to have done was just play stupid and say there was something wrong with the seat after he put it back together.
I would approach the dealer with this being more of a safety concern. That could cause burns to you or someone else. If the dealer still does not take you seriously, reach out to corporate. You can always file a complaint with the Consumer Product and Safety Commission. CPSC Home | CPSC.gov
What year and model do you drive? Looks like a softex leather interior?
This thread made me curious as for some time I was thinking about adding seat heater to my 4R.
A little digging through all posts by OP in different threads and times gives the whole story:
We picked up a 2010 sr5 2 months ago. 80k miles. Stock everything.
Bought the truck used and the cusion is breaking down on the outter edge. It's caused a lump in the seat and I think it's making the seat heater bunch up. The heater will burn your left cheek pretty good now. Just wanting to pull the cover up and see what's goin on under there.
Previous owner had installed seat heaters and Katzkin leather upgrade. My driver seat is now lumpy and the seat heater will burn your @$$ when on. Goin to attempt to pull the seat and skin, and see if they heater is bunched up, causing the lumpy pad and burning.
Yes, it's a faulty seat heater. It actually burned through the seat foam and has left a divot in the seat. I called about it being covered under warranty and they said no. I'll have to replace the entire seat bottom, with new foam.
I think I will pass on adding seat heater.:fear:
It's a 2010 sr5. The leather and seat heaters, we're aftermarket install by the previous owner. During an oil change, we mentioned the issue and they told us they would not cover it under warranty.
good sleuthing! personally wouldn't judge that as representative of all aftermarket installs, however.
Makes sense now as to possibly a bad install or faulty aftermarket heater.
Also, why it would not be covered under warranty. (refer to first sentence)
I have mine to install yet and I still will. Who knows what kit was used and with the adding of leather... just not sure. I think if it was a big problem there would be more posts.
matisgugle
