Using the cruise control and setting it 5mph over the speed limit is how i get to work. I do a round trip of 34 miles. Approx 28 miles is highway. I thought maybe i was running her a little ruff but The last two tanks i have been non aggressively driving and keeping in mind fuel economy.
I don't own a 4Runner, might in a few months. Recently looked at buying an FJ and researched that quite a bit, read a lot of their forum info. Turns out they basically have the same problem, and the engines are very similar. Last root cause I read was a weak thermostat, it fully opens early, the engine stays in warm-up mode which eats more gas. This doesn't set a code either.
This may or may not be your issue, but it might be something to think about.
Good Luck!
1engineer,
The issue alluded to with the FJ cruisers dealt with posters who measured this on a mainly highway drive to work, using cruise control. This would imply that there is little variance in the driving habits. Those users experienced a ~20% mileage drop with no additional mods to the vehicle.
Yes, the effects of the most gas mileage drop causes are cumulative, so seeing a 15% reduction from a combination of low tire pressure, a dirty air filter, and a relatively minor alignment issue.
What I understand in the OP's case is that the drop in mileage was SUDDEN with no driveability problems.
My TE with 8500 miles on it also suddenly felt like it was dragging a boat anchor, and yes, the parking brake is off. Mine has also dropped from 20.5 mpg to 17.3 mpg as measured between full-clicks from gas at the same pump at the same station. Toyota's response is a predictable "it's within the normal range, there is nothing I can do for you." Yes, normal for city, not on a flat highway. Again, no mods were done during that time.
Yes, it's possible that on a flat highway something knocked my alignment out, let air out of the tires between my weekly checks (and refills just before I check it again!) and clogged my air filter. Suddenly. Probability? Pretty low.
My point was most people forget about those most common things that decrease milage. Your case sounds different entirely and judging by your previous posts you are well versed in troublshooting as well as many posters on this board. The OP has 6 posts so not a lot can be gleaned from his experience, hence the reposting of "common places you lose fuel efficiency." I developed a spreadsheet for a guy one time who had a sudden loss of almost 30% fuel efficiency. This helped him to understand his truck's trends and when he made a change you could tell pretty quickly if it was helping or not. PM me if you are interested in something like this.
I just read that thread. The symptoms are straight forward, but require a mechanic's skill to diagnose and not just a scan tool. The issue I have with this theory is that if affects FJ's in the 40 - 60,000 mile range. Our 4R's are under 25,000 miles.
Symptom summary is:
- wet plugs, black residue (i.e. running rich)
- soot in the exhaust (which mine most definitely has)
- Scan tool showing a high variance in engine temperature in varying conditions
Fair enough, and worth checking, along with the "don't expect any help or understanding from the dealerships" although that's expected from people who'll use an impact wrench on locking lug nuts.
What was the final determination (s) as to cause of the above listed findings?
to add, not only may you have the wrong viscosity oil that could cause the problem or part of, but perhaps you have too much oil. Check and make sure youre not over filled.
Thermostat opening early/sticking open was the diagnosis. The engine would never warm up all the way for the ECU to get out of warm-up mode.
Thanks homeyclaus, I will keep an eye out for this possible problem in the future.
I first noticed this a month or so ago. I attributed it to the changing over of the gas blends to the 'summer blend'. Also, I'm now running my A/C nearly all the time, because at 7am its already 80+ degrees in Texas. I used to get at least "400 miles" per fill up, I'm averaging about 385 now. I need to check my tire pressure, but I've also seen it drop down to 17-19mpg. (I have almost 19k miles on mine)
lol, summer blend if you guys even have it down in texas, will only increase fuel economy.
Although I am new to this forum, I have participated in many "motor" forums (corvetteforum.com, bobstheoilguy.com, etc.) over the last 15 years. That said, the advice on this thread is some of the best advice/reading I've come across. I'd recommend that this thread be elevated to "sticky" status.
