diff fluid out the side of the axle??
Link817
Wheel seal issue??
anyone know of a good DIY writeup?
Does this take a special tool?
Just changed the fluid so I'm thinking with all the fluid in the rear end is the reason i'm seeing this now
Yep. Follow his write up and you'll be set. Just did mine about a month ago and they're still fine. Never done it before.
Edit: here's the link.
http://www.toyota-4runner.org/showthread.php?t=67299
I followed BFAD's write up and added pictures of mine to my thread as well. Look through last 3 to 5 pages of my thread for the 97.
Not a difficult job, but if you're going to replace the bearing and all while you're at it then you've got to be sure that the retainer is sitting just right or it won't seal properly. I had a real time with the shop I was dealing with, they couldn't get it right at all. They originally just assumed everything pushed tight up to the bearing. Anyways, some people have used Drcoffee's method and had success, others say he's wrong and toyota is right. You can choose. Either way he's got some measurements and all...
http://www.toyota-4runner.org/3rd-g...-solution-leaking-axle-seals.html#post1060244
