Difference in Trail/LE rockers???
BamaRunner
After searching the board, I'm still confused as to what differentiates the rockers on an LE and a trail. I want the NFab steps and have seen Ride's spacers. Is it the XREAS lines that make it so difficult to find boards/sliders/steps for my LE??? If I remove the XREAS and go with different aftermarket shocks will I better be able to find steps? I'm interested in the budbuilts or shrocks or metaltechs or whatever else yall recommend that I haven't thought of.
Thanks in advance.
Thanks in advance.
Basically the LE/SR5 rockers (exactly the same) are bigger and hang down lower than the Trail versions. Read this and hopefully you will get a better idea...
Rocker Trim How-to
TE = Shallow, more wrap-around style rocker panel
SR5 = Lower handing skirt-type rocker. Clear frame rails.
LE = Lower handing skirt-type rocker. Frame rails have XREAS lines and canisters mounted to the outside.
The spacers that RiDE offers will handle the height of the SR5/LE rocker, but I'm not sure how ti handles the XREAS lines. Any slider that has bolt on gussets on the brackets that get bolted to the frame should work with the XREAS lines.
My Shrockworks sliders did not have bolt-on gussets on all mounting points, but I was able to relocate the xreas line enough to make them work. Details on my slider installation can be found in my build thread (see my signature below). it also provides instructions on how to switch to TE rockers on a LE.
Do realize that nerf bars and sliders are NOT the same thing.
Okki
