dkyleb's Overland Build Thread
Absolutely gorgeous pics! Just read through each post of your thread and I was amazed at your DIY skills! You really transformed your truck! Nice legs in that pic using the bed, too ;)
Thanks man! It's been fun building it up and putting it to use!
Great looking rig. I like the good balance of diy and functionality while getting a more aggresive look without losing the original looks of the 4Runner. Very well done in my opinion.:thumb3:
Mallcrawler Monday:
Awesome build thread. Lots of ingenious mods here. Really see the thought out into each component instead of just throwing money and parts at it. Also jealous of your location! The island rocks. Hit me up if your ever out my way.:canada:
Thanks man! I really like watching your builds too! I'm from Edmonton, actually! If you're ever out on the island, shoot me a PM. It's awesome here.
Well, I haven't updated my build thread in quite a while. Time for some updates!
I hit a deer, so I decided it was time for a new bumper. It was built in just 2 days buy a local welder. He did an excellent job, very happy with it. Oh yeah, and I grabbed a cheap set of 35s from a friend. I'll run these for a bit, then probably grab a fresh set of KO2s again. Had to do a bit of bashing for them to clear, for now. Hopefully after all this work, I'll be able to get 5*+ of caster and not have to do any more cutting!
I created a harness for the light bar to plug directly into the fog light circuit. No need for an extra switch!
It was also time to replace a bunch of stuff on the front end. It had a really hard summer.
- Steering Rack (old one was leaking) + tie rod ends
- Wheel bearing assemblies on both sides, including inner seals
- Top plates
- Total Chaos spindle gussets
- Total Chaos cam gussets
- Moog Cam Bolts (ugh, gunna try them again...)
I decided to weld my spindle gussets myself. After completely disassembling them (and wrecking 1 ABS sensor in the process), I wire wheeled them and flappy-disc'd the areas that were to be welded. I then preheated the spindles with a tiger torch, and welded in stitches. I allowed the spindle to cool for about 20 minutes between stitches. I preheated every time before welding.
I pulled apart my LCAs and discovered the Moog cam bolts had some serious damage. Apparently, the sleeve on the forward bolt was riding within the oval holes used for alignment and wrecked the sleeve. They also caused some damage to the oval holes, which I was able to easily repair. Since I was going to use Moog bolts again, I decided to shorten the sleeves to match the length of the LCA bushings. I spoke on the phone to a Moog technical expert, and he was baffled as to why the sleeve was longer than the bushing itself.
Total Chaos cam gussets being welded in.
New KYB top plates installed. I have a feeling the ones that I put in originally were not properly assembled. Whoops!
Putting it all back together...
So, the truck is currently at Toyota getting an alignment. I instructed them to go for as much caster as possible. I'll update tomorrow!
Okay, so the front end has been done for a week or so... It feels like a totally different truck. Very happy with the rebuild. Still some finishing touches to do, though.
After doing all this, I realized I had a very stuck front driver's side caliper. I had originally planned on upgrading to 5th gen brakes in the front, but decided against it due to budget constraints.
As I went to replace the pads on the passenger's side, I discovered that caliper was frozen, too. Went ahead and replaced it.
Guys, I think there's supposed to be a bushing in there. Kinda explains the weird clinking noise from the rear end.
Not sure what the bracket is for... My original one didn't have a bracket. Toyota buddy say's the ABS sensors are routed a bit differently on the newer ones.
Much better.
Love your entire build and everything you have done to upgrade and mod your 4Runner! It looks amazing and wish I had all those mad skills to transform my 4Runner the way I envision it.
Another Courtenay t4r, I`ve seen this one around. I recognized the driveway too because my best friend used to live there and my old house is in the shot!
WOW!! that's amazing, 2 days? Did he already have the design? I can't image him being able to design it, measure, cut it all, weld it, and finish it smooth in two days. Looks great!
erinobr2000
