Dobinsons 5th Gen 4Runner Snorkel
It’s worth a shot. I honestly don’t know if it would make a difference but possibly. If you try it, let me know.
That's actually step 5 of the instructions.
It made a huge difference, the template was ~1/4" off on 4 or so of the screws. I adjusted the holes and bolted the thing on. Took me a couple hours taking my time, nothing hard, but definitely don't skip step 5. For I think it could be better worded in the directions.
"Check the template against the snorkel body. (INSERT: ADJUST THE TEMPLATE DRILL HOLES AS REQUIRED TO LINE UP THE TEMPLATE AND THE SNORKEL,) Align the template on the vehicle as seen in picture on page 2, and tape it down ensuring it is aligned with the top and rear guard edges and then pulled tight to the outer guard edge. and double check again."
Great to hear. I definitely skipped that step after watching some videos on YouTube. It would have alleviated some of the initial frustration but it still doesn’t account for my issue with the main hole (had to widen and elongate it more) as well as my other upper bolt issue.
Either way, good advice for those looking to do the install. It would have shortened my time a little bit for sure!
Pics required!!!
And I should say, I’ve had 5 people wave/thumbs up on the road and another 4 say something about how nice my truck is with the snorkel on. It draws attention to my rig that it wasn’t getting before which is fine with me. A snorkel is such a statement about your off road intentions that I think most overlook without it. It’s drastic and I’m really feeling it.
I also only used 3M VHB on the A pillar, the snorkel was pressing against it already after tightening it down, I don't think the VHB will have an problems. If it does, it'll take me an hour to fix with rivets, no big deal.
Looks great! And yeah, that’s pretty much the way my holes played out. I shouldn’t have skipped step 5. That’s my bad but I expected a product allegedly designed for our specific application to be spot on. I guess I was foolish for believing that.
Seeing that your holes lined up exactly as mine, maybe Dobinsons should adjust their template since it looks like they’re consistently off in the exact same way...unless this template isn’t meant for the 4R.
Either way, thanks for sharing. Step 5 is vital for saving some time.
Few pics of my first time out with the snorkel. I hit some water crossings that would have had me nervous before. Now I’m care free and loving it. IMG_2242.jpg
Will the TRD CAI work with this snorkel or will I have to revert back to stock? I skimmed the thread but saw no mention throughout.
[MENTION=148378]Crikeymike[/MENTION] will there be a Black Friday sale on the snorkels coming up?
Yes, Dobinsons will do a black friday sale across the entire product line. Follow the social media accounts for the announcement and coupon code later in November.
Great to see the snorkel on a 2010. I had wondered if the antennae on it would get in the way of the install as I have the same year model.
I had the same issue and I couldn’t find many snorkels on a 2010-13. The only issue with the antenna was squeezing my hand up to reach the highest mounting points in the fender well. That’s a tough one and will likely invoke some swearing and a sore hand since getting around the antenna mount is a thing. I didn’t have to modify anything though so that was great!
I’ve used the snorkel in actual applications where I would have had some genuine concern about ingesting water so it’s been great. We just got our first snow so I’m curious to see how that pans out. I know I’ll have to turn the head backwards which I see a lot of guys do anyways in the desert and in Africa just to cut down on dust flying directly into the intake.
Just installed my dobinson snorkel on my 5 th gen. I managed to get it to work with a S&B cai. I had to get a custom pipe to fit in between. Works like a charm, my template was also off on so make sure to spend time rest fitting before drilling.
Would like to see pics when you can post some. Saw where the vendor and S&B both said it wouldn’t work yet here we are. Want to do the same thing to mine.
This season has already dropped two measurable snowfalls on us. I’m gonna get really annoyed with flipping this snorkel head around every few days. Anyone run a prefilter or consider this to avoid the constant flipping around of the head? I’m not interested in a sock right now either. Part of the reason I chose this one.
If there are no door clearance issues, just leave it backwards until the snow season is over. 1 screw and 10 seconds isn't really worth complaining about I'd say.
Yes, some guys run prefilters but those do reduce the airflow by the way they work
A simple “no” would have sufficed. I’m aware of both the process of spinning it and the option of leaving it backwards (against the instructions which tell you to keep the head forwards). I was looking for input from anyone who considered using or running a prefilter.
Any guys out there with any "driving in heavy snowfall" experience while using the snorkel care to share their feedback for others?
