Crikeymike
Senior Member
Do the doninsons rear springs left right compensate for drivers side lean ? I just installed c59-701's and the drivers side is an inch lower then the pass. side. No kdss. Should i swap the springs? Add a spacer. Im assuming the shop that instaled them put them on the right aide if they were labeled.
Those 701V coils are even height. The KDSS rear coils are offset height.
1" difference? My guess is that either you have a lot of weight on one side, or both coils weren't installed properly.
What accessories do you have in the truck?
**EDIT: now I see that you have every accessory known to man, and most likely the load is not balanced from left to right, creating a lean. You say you have all this:
i have a cbi tire carrier rear bumper with every option with a 35" tire/rim, 2 full jerry cans,4 maxtrax, trasheroo, full steel skids, gobi rack/ladder, ostritch wing awning, 130lb Rtt, 500lbs+ worth of pullout kitchen / fridge / drawers stocked with tools/recovery/misc gear. its got to be 800+ lbs then on top of that if i carry 2 more passengers. and on trips i could add upto another 100 lbs back there is stuff (food/drinks/cloths/gear etc)
