SpeedyKevin
Just got my 302 coils in. Super fast shipping from the folks at Exit Offroad!
That's a super common setup, 2.5" front and 1.5" rearLooking for some feedback on this setup before I pull the trigger.
5100’s all around (zero setting up front)
front C59-302
Rear c59-505
New UCA
2018 OR w/out KDSS. No extra weight on the truck and would like 2.5 -3” in front with still somewhat of a rake. My current rake is 2” (20” up front and 22” in rear, hub to fender).
Thanks.
Sent from my SM-G973U using Tapatalk
You'll have to wait for someone to chime in that has that combo.Thanks, any insight on how this drives on road as compared to stock? Off-road I would assume it’s an improvement.
Thanks.
Thanks.
On and off-road changes drastically for the good. Nose dive and roll gone, on ramps to the interstate improve. Only off-road I have is beach ruts, gravel roads with holes that you would slow down in a stock ride. I feel the more speed you have the better the float. Didn’t install the UCAs yet. Didn’t have them initially during the install and alignment was no issue. They are in hand if the ride gets squirrelly.
Thanks and the pic helps.
By chance have you measured the achieved lift front to back? It looks like you may still have a little rake which is what I would prefer to keep, but maybe not the 2” difference I currently have with stock.
MRR's (adjustable height with resi, no adjustment) are being replaced by the MRA's (w/resi and 3-way adjustable).[MENTION=148378]Crikeymike[/MENTION] are the IMS shock/struts replacing the MRRs?
I am budgeting to go from my GS struts/shocks to an upgrade next year. Is it better for me to do IMS (money saving) or MRA (fully adjustable)? I searched the thread, but I didn't see a good comparison as to the advantages and disadvantages of each. Just curious what's best for me to upgrade to...
:snacker:
No I can't, it won't let me until your post count gets higher. just send me an email to [email protected][MENTION=148378]Crikeymike[/MENTION]
Hi Mike
Thanks for all the info. This convinced me to go with Dobinson instead of icon. I joined so I could PM you about the discount code, but I guess I can't figure out how lol. Is there a way you can message me from your end?
They're digressive.
Higher dampening ratio at low shaft speeds to control body roll and movements and lower damping ratio at higher damping speeds to allow suspension to soak up bumps
That was a really old post that I've just fixed.Is this true for the IMS struts/shocks as well?
