Crikeymike
Senior Member
No, just the forum member discount.Any deals for June Mike?
And stocks got so wiped out from last month, it's a good thing there isn't a big discount this month too.
No, I don't think so. Would be easy to tell though, just set the LSC all the way up or down and turn the HSC and see if there's any difference. I'm pretty sure there's not.Mike, in your video you show that when adjusting the big knob (HSC), the LSC know will also turn.
Does that count as a "click" for the LSC knob?
Yeah, it doesn't count. You'd still adjust the LSC as needed. Just verified.No, I don't think so. Would be easy to tell though, just set the LSC all the way up or down and turn the HSC and see if there's any difference. I'm pretty sure there's not.
You can use the Prado 150 settings that are listed in the pamphlet that comes with it and then adjust from there. Or start fully open on all settings and tighten up until you like itThanks for checking. Do you have recommended settings for different terrains?
How are these holding up for people who have some miles on them, any complaints?
Treating myself to a birthday present and trying to decide between these and bp-51s
Has anyone hand measured the body and the shaft of the MRA shocks?
I have a hard time understanding why Fox 2.5 for 0-1.5" lift and MRA for 0-3" lift have the same published extended length of 24".
The Icon 2.0 has a published length of 24.5 but I measure it 24 and it is for 1-3" lift. It really does provide a lot of down travel with a 1" spring.
Stock is 22" hand measured.
So someone is over or undershooting their numbers.
Even better, please post your rear down travel with the MRA and let us know what spring you have.
I guess I have two more questions.
1/ What exactly is the rod/shaft thickness? The video leaves that a little open. The picture says "heat treated 18/22 mm". Is it 18 or 22? It does look big vs the body, 22?
2/ What is the HRC surface hardness of the rod?
That's correct!!Based on other dobinson shocks, id say 18mm is the shaft size for the 4runner/56mm body. The 22mm size is for the 66mm shock body.
18 goes with 56mm and 22 goes with 66mmI guess I have two more questions.
No idea on your 2nd question. Dobinsons has released as much info as they can on these, all shown in the specifications
