Does anyone have the TacoTunes Amp rack?
Pschiller86
Does anyone know the dimensions of the usable space on the taco tunes 4runner amp rack?
I’m trying to determine if my Pioneer 5 channel amp (12.4” x 7.87”) and LC7i will both fit under either of the front seats?
Thanks everyone!
Thanks everyone!
I bought it but it's in storage. If I can get to it I'll post up dimensions. Honestly I'd just get on their chat and ask.
My plan is to put my OEM Audio amps on it plus a HAM radio.
I tried chatting with them, but they don’t even give out dimensions. They just stated it’s designed to work with their amps. :smashputer:
Seems like it’s too tall in profile to use with any other amp but the TacoTunes amp. IIRC the height of their amp is really small compared to most other amps carried on say crutchfield. It’s also hard to visualize this but I’d be concerned about being able to reconnect seat cables.
I guess I’m just surprised nobody has tried it.
Their 4 channel amp is listed at 1 9/16” and most amps on Crutchfield are 2”
The rack is as wide as the track under your seat as it uses the bolts for your seat to hold it down. I will see if I can get measurements of it under the seat and how much space is between it and the bottom of the seat.
I have it holding an Alpine PDX900. Works fine, plenty of room. It is actually flimsier than I though it would be, but gets the job done and does a nice job of hiding the wiring keeping things clean.
Thanks everyone!
well.. i could barely fit a rockford prime r500.1 (1.98 x 6.77 x 8.5) and the lc7i together under the driver seat. I have a prime r300.4 (1.98 x 6.77 x 13.19) under the passenger and that fits only by itself
Amp rack? Who needs an amp rack? I mounted my JL 250/1 Class D under the seat, screwed it into the carpet and it hasn't moved a centimeter. Did the same thing in my 08 4th gen. Removing the seat to bolt an amp underneath seems like overkill to me and I'm OCD with my installs.
I researched their amp racks and have used a lot of TT's products but these just seemed flimsy from all the reviews I saw/read
Depends how big that 5 channel is, I was able to mount in front of the vent
Sorry not related, do you have component 6s up front? Im debating on adding 6.5 components vs getting the 6x9 components up front and adding a small 5 channel amp. If so, would you recommend going that route? Thanks!
I bought one but sent it back. It was too tall to use with my 5 channel JLAudio amp. I ended up cutting square pieces of 1/3” plywood and slid a piece under the carpet below both front seats. Then used wood screws to mount through the carpet into the wood. I have the anp under drivers seat and an audisson bit 10 under passenger seat. I just installed a ham radio. I used the super duper velcro to stick the mounting bracket to the carpet. This is under drivers rear seat. No room under either front seat. I did use a dual amp wiring kit when I installed the amp and ran 2 gauge wire to a double distribution block. This allowed me to grab always on power from the spare fuse block for power for the ham and a fridge receptacle.
erinobr2000
