Door Locking and Unlocking Function
1engineer
Moderator
This is for all the new guys trying to change locked/unlocked doors depending on speed or shift lever position using procedure in manual:
When the manual says to hold down appropriate lock/unlock button for approximately 5 seconds it is lying. In order for a change to occur it had better be 5 seconds - not 6 or 7 or 4 or even 4.9 or 5.1 seconds. FIVE SECONDS exactly! I had forgotten this little tidbit as my TE came with the doors unlocking in park and locked when in drive. I want all doors unlocked all the time and just spent 45 minutes on an operation that should have taken me 5 minutes. Kids, use a watch and get the 5 second time exactly!
I managed to get it right the first time when the 4R was purchased. Tried it about a year later and it didn't work. I got fed up with it and left it until I found out the settings were adjustable in the Techstream settings.
1engineer, you have a lot more patience than I do!
Well now you tell me! I bet I've tried this a dozen times, each time ending in frustration and a few colorful phrases.
Is the "unlock all doors with one press of the unlock button" only a Techstream feature or can you do it by yourself?
I don't recall being able to do that with TechStream. One press will only unlock the driver's door, which when you think about it, is much safer for preventing someone from car-jacking you.
jbstrd:
You are really close to me...come on down to Portland. I'll let ya play with your rig via laptop & techstream.
You know, you CAN have the dealer do this for you. I know, a big waste of time.
Or, you could send $30 to China to get the OBD Cable & Software and do it yourself. It is relatively easy if you are savy with computers. It requires XP or "XP Mode" (Win7 Pro), or Virtual Machine with Mac.
jbstrd:
I may have to take you up on that offer one of these days. Thanks.
As far as the danger, not sure which is more of a risk to me, a car jacker or my wife being stuck outside of the locked passenger side when I forget to hit the button twice.:50cal:
I believe it is a feature with and without techstream. I don't have the manual or Nashman's pdf files on this computer but I think it only involved pressing the lock and unlock buttons in some way.
Found these for the limited... Might work for the Trail and SR5
http://www.toyota-4runner.org/514500-post10.html
http://www.toyota-4runner.org/514830-post17.html
Ambrose67
