drl on/off in techstream
meanbaby
looking to turn off drl on 15 trd with techstream 10.xxxxxx, cant seem to find it, anyone knows which menu/sub menu i can find this in?
thanks
-pete
Select "Utility" when accessing any module, there should be a "Customize" option in there; that will let you play with customization options.
Did you check to see if you could change it through your Entune headunit?
Just verified with dealership (I'm actually employed by an auto group with a Toyota franchise), there is not a customization setting in Techstream for the DRLs on my 2016. For now I just used the relay pin bend method and that will work good enough. I actually switched out the foglights to the 2 in 1 LED kit that the dealer sells and that has a DRL function (led ring around the lens) and a toggle switch on the dash to turn it off and on.
I don't get it.. My DRL's stay off unless I turn them on...with a switch...that says 'DRL'. So why is there a need to disable them if you can control them or am I missing something?
I prefer to have the Parking lights on w/o the DRL's on, from the factory that is not an option.
I don't think you can disable the DRL's in Techstream, I just bent the relay pin like the above poster.
Ah ok, makes sense then. Thanks for clearing that up! :)
