Dropzone's 1994 4Runner Expedition/Overland Build
Man that sucks. In Tennessee, it's not strict at all. You aren't even required to have fenders here
i have driven all over the country and seen some that would blow me away compared to the 4Runner...newer jeeps around here with barely any coverage at all..oh well
On to Operation Keep the Law Happy part 2
Added some flexible rubber fender flares compliments of Amazon prime
Also pulled the steering wheel cover off and found some nastiness, found a good deal on the Wheelskins cover
Went to get gas and the gas door wouldn't open. Popped it open and found the lower hinge mount had popped lose, slapped some epoxy in there and clamped it, works like a charm ..for now
wiped up the excess, looks like crap but who cares on the gas door
Perfect job with that steering wheel cover.
Thanks!
So the missus agreed with me that the flares came out looking like crap so got the go ahead to order a set of flares
https://www.junglefenderflares.com/toyota-4runner-hilux-surf/
Should have them in time for a Father's day install
I busted out my $64 Harbor Freight Booger Splatterer (aka flux core welder) and used electronic snot to mount some light tabs
I picked up these eBay 50w Light Cannon knock offs last year. Nice thing is you can use Vision X filters on them so spots can turn into floods with one set with out the $500+ price tag
Was trying to find a simple way to sort of hide or camouflage the body line that was opened up when I swapped bumpers..dunno if i like it but it will have to do
Saw these on kickstarter or somewhere awhile ago and after shearing a valve stems a few years ago thought they were a good idea.
They allow you to replace the valve stem from the outside of the rim with out breaking the bead. Cheap insurance to have in the trail box
Was trying to find a simple way to sort of hide or camouflage the body line that was opened up when I swapped bumpers..dunno if i like it but it will have to do...
20170603_150858_zpsiepy4c1x.jpg~original
[/URL]
Looks tasteful. I like it! and the truck's looking sexy, Robb.
You might also be able to find side-marker/signal lights that would screw onto those threads for added visibility.
Just pullin your chain... I actually think some panels bolted on there would look pretty sweet. Flush mounted kind of like what the Rock bouncers use? Aluminum even... Ian from extreme off-road showed how to mount them in an episode online..
https://www.bluetorchfab.com/collections/brackets-tabs/products/btf-panel-trick-tabs-10-pack
Something like these. Just cut your panel to be 1/4" larger than the inside of your tube so it'll end up flush with the outside. Bolt your tabs on and tack them on.
Sent from my LG-H830 using Tapatalk
In Preparation of Operation Lower the Rack I removed the upper brake light
Before
After 23 years a lot of crap made it way past the seal
Toyota even used cone washers on the rear deflector...go figure
Added some KC cyclone LED's to use as brake lights
The pic doesn't do it justice, they are pretty bright
20170611_170317_zpskkg2vtwi.jpg~original
[/URL]
So like a lot of people I got screwed by :flamethrwoer2: photophucket :50cal:when they decided that it would be cool to charge people $400 a year for hosting pics. I have 13 years worth of threads on various forums that got fubarred.
I will do what I can to reconstruct this thread when i find a new hosting service that is either free or doesn't charge the same amount i paid for this project
Haha
Use google photos
i tried to use google photo, copy and pasted the link and this is what I got
https://goo.gl/photos/ut4d5yPqV1PkbRQa8
ut4d5yPqV1PkbRQa8
enlighten me
I don't think they do 3rd party hosting either. Please correct me if I'm wrong.
that is what I am finding too
Why dont you just upload the pictures to the forum? Why use 3rd party, links, etc?
when you have the same build thread on multiple forums it is a PITA to upload the same pics each time, copy and paste the links into one post, than copy that post into the other threads and you are done
AF1QipOlC1iWOhyW8rS1cY6CvbnGrALMl1Y0D2oZuCcP
edit: figured out how to use google photos but it is a pain to use
Using Google Chrome:
Right click on the google image, 'Open image in new tab', right click on the new tab image,'copy image address', paste that into the image box URL form.
6lQrsiNEwvAov70zyh9U5i-ZXMVmhm9OWZ7W4T3NLGBXr7EPPZ70pK4HOlNtRsCeHA5lyWAs6J5aiU6qEIZq53p30qXMvOnC9N7Sm5w1wTB55GHA9x6orZKvs-dChkQ7xX6ltG4yWzkT-wjKS7VA2ClS3YKEifZJIL2sbYgSw6Bi-xcB8D28kNfmErdHTaxeFNF-pkj8xFpZ9-GE9EeyPkY1H4Ndaz0uEA6H88qgbJO_PhYSwYmMbojPtomnhI8tUMT44U1aqGl4v9Ls10Xquido40Kena-SEgS2Ahl_XUqBstMY61KPGEfsBF9i_fNz0xIbwW_HFSoLnQVmqFPrALffWsvGnkN3PAbk7q9pZNIABgdsGaNiJtqlagL0GqQ80j33ZU_VPje1Cfhayuk5ulKuwRA9C2xWYVAY2lrhJIaTUS1_kbjEoScY6VGmDj92UfwAeQQ6MblN_7kKrd772uPFOXYloKMZVegjcZdtX7sTStS3YgIFNgi-O0pdkDDsq5fnTZUsiVxe2J-3jKA8Y9oXv0RejXEYwF_8J0P63Pv_1NWm4BPxQIuxg6wdym9v2P639Si94H4Y6wQUjj9eO32HciATUYWveWazGl4J86wUVBDs2OOJh469=w800-h547-no
set up a flickr account and it is easy to use, you get 1 TB of free pics hosting so
https://thelabradorforum.com/threads/posting-a-photo-from-flickr-update.10872/
20170617_095708 by ocdropzone, on Flickr
so now that i sort of have pics figure out here was an short little adventure on the 4th when my frigging throttle cable broke- there is a little plastic doohicky on the end of the cable that runs into the gas pedal.*
that little POS broke off somehow so zip ties to the rescue
20170704_134155 by ocdropzone, on Flickr
​​​​​​​20170704_134057 by ocdropzone, on Flickr
same thing happened to my dad's 85 Bronco. Nice fix
Ambrose67
