dual battery set up
Ive always wondered if this could be done with the second battery located else where on the rig.
Yes, yes it can. check out my build thread. AZBubs poor man build and budget Adventures.
http://www.toyota-4runner.org/3rd-gen-t4rs/218624-azbubs-poor-man-build-budget-adventures.html
My house battery is going in back. I didn’t want my second battery sitting on top of the exhaust headers. Contrary to popular belief it really wasn’t that hard to run the wire.
I still have to install jumper wire from main battery to the system. I’ve been driving it around checking for any rattles and whatnot.
Ballistic Fab 34/78 box. Works perfect for the Vatozone AGM
anyone ever move both batteries behind the rear seats?
I want to tube chassis the front end of my 4runner and thus remove the inner fender well supports at the fire wall and will use tabs and then probably thin sheet metal or plastic panels to seal it back up and want to move both batteries to the trunk area.
You should have a thicker gauge ground wire from battery to body! Looks good though.
the house battery ground is 1/0. I have enough 1/0 to do the big 3, which is the next To Do on my list[emoji106]
Sorry to resurrect, but I just joined the forums to cover a dual battery setup I'm working on, and I can't start threads yet...
I want to share because I have not seen it done this way yet and may help give some others ideas for mods custom to your needs. My setup uses an (almost) stock starter battery size (I believe stock would be BCI size grouping 24, whereas I am using BCI group 35), along with a group size 27 75 amp-hour deep cycle RV/marine battery as auxiliary. This is almost the same height and width as the 24 or 35, but about 2 inches longer.
To make this fit I had to make 3 adjustments (cannibalizing metal).
1) I cut out the bracket that the battery normally sits on top of. This gives more vertical room to play with, which was important for #2
2) I cut into the sheet metal wall toward the fender of the driver's side. Since I lowered the batteries in #1, I didn't have to cut much to allow the starter battery to slide under toward the fender. This gave me JUST ENOUGH room for the 2nd battery, except...
3) I did need to make a small change to the fan shroud. I didn't want to open a wide hole as many mods do, but I needed to remove the top bolt bracket because the 2nd battery rests snug up against the shroud and that tab would be in the way.
This is a WIP as I wait for my coolant overflow bottle to arrive so I can relocate that. You'll also see that I modified my fuse box, bringing it further toward the engine and away from the wall. I cut off the original mounting brackets from the fuse box and fabbed up a mount for it. This gives a bit more room against the driver's side wall to add a solenoid, secondary fuse box, or bus bars. I really like 42s' hinged secondary fuse bracket - I'll definitely be using that for inspiration.
Peace!
Before I take the plunge
I really like your set up! It's clean, I've been doing a bunch of research on this, it's the mod I'm currently in progress with. I've completed the big 3 upgrade with a 200a fuse between the alternator and the battery, I've upgraded the alternator to the 140a from 95 cadillac deville.
The dual battery set up is pretty straight forward my only reservation is what is necessary. I've seen setups with dc/dc chargers, switches to jump start the starter battery, and kits that range upwards of $500. What makes these kits better than the ones on Amazon?
Before I take the plunge I'd like to know if the dc/dc charger is completely necessary, if there is a specific solinoid that is recommended, and I would definitely like a switch to jump start the starter battery just in case, is there one that is better than the rest?
Thank you in advance
2 ODYSSEY ODY35-PC1400T
COLOMBIA OVERLAND dual battery tray
IBS Intelligent Dual Battery System
IBS Relay Booster Module
Peace!
Looks nice, Have you decided what kind of system you are going with to connect the two batteries.
BillM777
