E-Brake Idiot Light ON
octanejunkie
Elite Member
The dashboard light for the hand brake comes on and goes off by itself on my '99 and playing with the handle doesn't seem to make a difference.
What's the fix here?
TIA
check the connector and or switch. it is located on the handle under the console. that should give you some idea as to what is going on. pretty simple.
yeah brake level, or that sensor, also from previous experience on a Honda i owned the brake light stayed on when there was a brake light bulb out but that may not be the case with Toyota.
All brake lights working, fluid level in the reservoir is good.
Light is intermittently on, so I'll check the connector and switch. Do I need to remove the console to get to it?
Sent from my Nexus 5X using Tapatalk
BillM777
