Eibach Pro-truck lift
PRO spring update:
To ensure the Fox shocks really work to their true capability we're only going to be able to lift the front about 1.8". This would make the front and rear level, which looks great on a PRO. Also, if you like the factory rake, you could always add our 1" rear spring.
No UCA needed.
Thoughts?
Interesting, as I already have your 1" rear coils matched with a 2" front cornfed spacer, and there is slight forward rake, so this could work out perfectly. (Front being slightly higher.. havent got actual measurements)
I'll place an order when they are ready!!
Sent an email for the patch as well
Ryan I think the 1.8" front lift would be great for PRO's (cant wait!!)... So I wanted to ask are you guys developing anything for the rear (new spring that would work with FOX Shocks)? What would you suggest if lets say you put a load in the rear or go with a new rear metal bumper with tire carrier to keep the rear end from being below the front? Thanks
For the rear you can use our current 1" lift spring and we also have a heavy duty rear spring and adjustable rear setup on the way.
Pro kit with 3rd row
I'll admit I'm not a genius on the different coils but can't find anything saying good/bad for this kit with a 3rd row. I don't use the third row often, but when I do it's for around town driving. Other spring kits often call out different springs for a heavy load in the rear with aftermarket bumpers. Are there any concerns I should have running this kit on a SR5P with third row? I do not plan to add any aftermarket bumber in the back.
We've installed this kit on a bunch of rigs with the 3rd row and it works great. There were a couple 7-8 pages back I believe.
I'll probably be going with this lift kit in the future. I know that UCAs are not needed, but would I benefit from them if I do a decent amount of high speed (80-90) driving on the highway? If so, what brand would be recommended? I'd like low-maintenance, and a good price, but not at the expense of quality. I do very little off-roading.
I’ve got JBA for 7K miles. Quality, performance, price, A+ . 10 minutes grease every 3K miles, that’s about it.
IMO, not really necessary.
Test day!
How would you guys feel about 2.0 front coilovers paired with rear resi-shocks?
