MY06T4R
Member
Parts needed
1 Mercedes E320 engine fan
1 Painless performance 185 on 175 off fan switch part #30111
1 Auto Meter radiator hose sensor adaptor part #2283
10' 8 gauge red wire
10' 8 gauge black wire
1 Toyota 4 pin relay with big spades
10' wire loom from harbor freight
1 fail-safe 170 degree thermostat part# 7302-170
1 felt pro thermostat gasket part # 35555
1 15 amp mini fuse
2 gallons of antifreeze
4 3/8 nuts
15' of 18 gauge wire
2 National Hardware® 5" x 7/8" Zinc Flat Corner Brace
Model Number: N234-955
2 National Hardware® 4" x 5/8" Mending Braces
Model Number: N272-732
10 zip ties
1 pack of washers Grip Fast® 1/4" Grade 8 Zinc Flat Washer - 93 Count
Model Number: G8FW14-93
1 pack of lock washers Grip Fast® 1/4" Grade 8 Zinc Split Lock Washers - 93 Count
Model Number: G8LW14-93BB
1 pack of bolts Grip Fast® 1/4"-20 x 2" Zinc Grade 8 Hex Bolt - 16 Count
Model Number: G8HB142-16
1 pack of nuts Grip Fast® 1/4"-20 Yellow Zinc Grade 8 Coarse Thread Hex Nut - 54 Count
Model Number: G8HN14-54
1 10 gauge wire end loop for ground
Optional Parts
1 can of Rust-Oleum, Cherry Red 252459 Automotive 12-Ounce Enamel Spray Paint
1 Denso radiator part#221-3124
I used the pre-wired air suspension relay location and 50 amp under hood fuse, I ran a 18 gauge wire to the inside and used a blank fuse location that was ignition on and a 15 amp fuse. I ran the fan ground wire to the battery.
Here is a link to the video showing the duty cycle of this fan and how quick it cools the coolant down. I just uploaded it a few minutes ago.
YouTube
1 15 amp mini fuse
4 3/8 nuts
10 zip ties
Optional Parts
YouTube
