Engine and differential questions
INDYMAC
Does the 2012 1GR-FE engine in the 4Runner have dual VVTi? Does it have the D4 DI (direct injection) fuel management system?
Is the rear diff in the RWD SR5 a Torsen type LSD, or is it an open diff?
Thanks.
Thanks. Looks like MPI instead of D4 DI.
Still not sure what auto LSD is. Does anyone know how it works?
Limited-slip differential - Wikipedia, the free encyclopedia Scroll down toward the bottom and see "Electronic LSD".
The sr5 and TE have an auto LSD (ABS based I believe) rear diff not a Torsen, based diff. The Limited has a Torsen center LSD diff which is lockable. The TE's rear diff is lockable.
The 2WD's (SR5/LE) have a LSD, but the 4WD versions do not. Since the TE is 4WD only it does not.
"Rear-Wheel Drive with Automatic Limited-Slip Differential (Auto LSD)"
