Engine misfire
mschlapa
I have a 96 that is throwing a trouble code that says misfire cylinder 4. What is the firing order and is it most likely a coil?
could be wires, plugs, or coil pack. I had a cylinder 3 code a couple months ago and replaced the plugs and wires. Really not that expensive or time consuming to do. Fixed the code. You can try swapping coil packs first and if that doesnt work, try the plugs and wires.
