diverscale
Member
I know that on the back cat flange because of the metal expanding and contracting the JB Weld high temp will crack off in time. :-( Most likely the metal around that hole is extremely thin and if you try to weld it shut it will most likely make
this hole worse.
So this I how I fix these cat back exhaust issues:
1.) I buy a replacement rear cat exhaust hanger.
I cut the nuts off and use stainless steel bolts and
nuts with washers so they don't rot up and can be
removed again.
2) If the flange on the cat is rough. I use new oem
gaskets with permatex ultra copper maximum temperature
rtv gasket maker to help the flanges reseal with the new
gasket.
3.) Then I use Northern Stainless exhaust because
Toyota OEM exhaust are insane. Walker only last 4 to
5 years in my environment then they rot off.
Ebay Link to Northern Stainless exhaust 1996-2000
OR
Ebay Link to Northern Stainless exhaust 1999-2002
What? they sell those as stainless steel?
These two rear portion, even in the top quality walker, rot off in about 4 years here also. I'll keep that in my favorite and hope they will still be making them when I'm again having to replace this exhaust.
