Expansion valve location?
Islands
Does any one know where the exapansion valve in the a/c system is located?
I have a 97' and I am getting ready to change the a/c compressor. I thought I would flush the system and replace the dryer and expansion valve "while I'm at it" as recommed, if the expansion valve isn't too hard to get at.
expansion valve/evaporator location?
Hossmaster,
Belated thank you very much for the pdf, very helpful!!
When I look under the glove compartment at the bottom of the black plastic housing, is that the evaporator case or the heater core case?
Thanks again!
Here is the diagram that will show you the two different components and their place under the dash. Good luck!
also how to remove the expansion valve
Thanks again, for the excellent (and speedy) reply! Those pdf's are super helpful!!!
BTW - If anyone expereinces the common nose/bearing failure on their original Nipondenso a/c compressor, I have located a source for a new (not reman) Sanden/Behr copy. The new compressor, dryer and o-ring kit was $215 plus shipping. A lifetime warranty is available on the compressor for $25 extra.
Ac-26?
would you happen to have a pdf for page AC-26 of the manual. helping my buddy with his AC system and having some difficulty getting the cooling unit out
increasedc
